Average Bullet Velocity Inside the barrel
10 replies · 11K views
waterwalker10
The M61 Vulcan cannon is a Gatling Gun-type weapon deployed on an aircraft. It fires a 100g, 20mm diameter projectile at a rate of up to 6,000 shots per minute. Barrel length is 170cm, and muzzle velocity (speed of the projectile leaving the barrel) is 1030 m/s.
-Assuming constant acceleration, what is the mean (average) velocity of the projectile in the barrel?
(It has been 8 years since a physics class...not looking for an answer but an arrow in the correct direction. Thank you)
V=D/T
[tex]\overline{V}[/tex] = [tex]\Delta[/tex] Distance/Time
[tex]V^{2}[/tex]=[tex]V^{2}_{0}[/tex] + 2as
Where do I start...I began with the second equation. V = 170cm / T Well if it shoots 6000rpm then it would be broken down to 100rps. Given that I would say that fires a bullet every .01 seconds. Plug the variables into the equation.
V = 170 cm / .01 sec or 17000cm or 170m/s
If you see the muzzle velocity of 1030m/s then you would know right off the bat that 170m/s is wrong.
So I used the second equation...and came up with some crazy answer that I know is definitely wrong. See below...
10302 = [tex]1030^{2}_{0}[/tex] + 2a170
1060900 = 0 (Initial Bullet Velocity is zero) + 2a170 (Solve for A)
a = V2/2*170cm
a = 1060900/340cm or 3120.29cm or 312,029 meters
Plug back into the equation
1060900 = 0 + 2*312,029*1.7
And they magically equal. Some how I think I might be using the wrong equation but I need someone to help me.
To achieve this answer you need to know how much time the bullet spends in the barrel.
[tex]V^{2} = V^{2}_{0} + 2as[/tex] [1]
[tex]V = V_{0} + at[/tex] [2]
Divide 1 by 2 to eliminate a, as we don't know it. V0 is 0
[tex]V = \frac{2s}{t}[/tex]
[tex]t = \frac{2s}{V}[/tex]
which is t = 2 * 1.7 m/ 1030 m/s = 0.0033 seconds.See where you can go from there...:wink:
So it would be fair to say that the bullet travels the length of the barrel in .0033 seconds.
Solve for Avg Velocity...
[tex]\bar{V}[/tex] = [tex]\Delta[/tex]d / [tex]\Delta[/tex]t
[tex]\bar{V}[/tex] = 170cm/.0033 secs = 51515.15cm/s or 515.15m/s
Would you have to change the time to correlate with cm and not meters?
[tex]\bar{V}[/tex] = 170cm/.000033 secs = 5151515.15cm/s or 51515m/s :confused:
Wouldn't the bullet be more close to it's terminal velocity? Or because this is the "average" velocity, you wouldn't have such a large number...?
I'm trying to learn via a few MIT/Stanford University lec. videos...
the average velocity should be the middle point, of your velocities, because acceleration is constant, therefore it accelerates from 0 to 1030 in the length of the barrel.
(1030+0)/2 = 515m/s is your average velocity.
i give the answer because you have already stumbled upon it, but hopefully my view of things allowed your mind to take an easier path to the answer :)
hit back with any more questions and i can go into further detail
Not quite sure what you mean here. 51500 cm/s is exactly the same as 515 m/s
Get this idea out of your head quickly. This is confusing and illogical.
This is correct but I prefer my reasoning as the mathematical derivation from the equation provides a mathematical basis, in addition to physical intuition (which can sometimes be flawed).
Well good to know I was on the right track. I understand mean as average and only average. If I wanted the middle I would take the length of the barrel and divide it by half to find the velocity at that point.
When I was in my algebra class I was taught to simplify. I guess it isn't wrong but is not fully relative to the muzzle velocity which is in m/s.
Oh and totally forgotten the seconds issue. The answer was in seconds not m/s or cm/s...
THANK YOU! I'm starting to understand now!
Then to find the acceleration of the bullet inside the barrel I would use the following formula.
a = Δv/Δt= (vfinal - vinitial) / (tfinal - tinitial)
Initial thought was to use 1030m/s which is the muzzle velocity given above. And .0033 is the time it takes the bullet to travel the length of the barrel.
a = (1030-0) / (.0033-0) = 312121 m/s
For some reason I believe that this one is correct below. [tex]\downarrow[/tex]
For Vfinal I calculated 170cm/.0033 = 51515cm
a = (515.15-0)/(.0033-0) = 156106 m/s
Correct?
This one is indeed correct. The unit of acceleration is [itex]ms^{-2}[/itex]
You already nearly computed this correctly from [itex]v_f^2 = v_0^2 + 2as[/itex]
in your first post (except for the units)
The difference in the numbers is round-off error. If you round off the numbers to 3
significant figures, you'll get 3.12 * [itex]10^4[/itex] [itex]ms^{-2}[/itex] from both calculations.
Here you use the average speed instead of the final speed.
So is this
3.12 * 10[tex]^{4}[/tex][itex]ms^{-2}[/itex]
the correct way to write acceleration?
waterwalker10 said:
So is this the correct way to write acceleration?
Yes. Oops, it's [itex]3.12 * 10^5[/itex] [itex]ms^{-2}[/itex]
Excellent. I've been watching a few more lecture videos so they seem to be helping too. Thank you! Mark this one as solved!
