Average force in stopping a block
16 replies · 3K views · last reply
ride4life
A 300kg block is suspended by a cable.
a) what is the weight of the motor block?
b) the cable snaps and the block falls 3 metres to the ground below.
i) calculate the time taken for the block to reach the ground.
ii) calculate the impact velocity of the block with the ground
c) if the block comes to rest having caused a 1cm dent in the block (ie traveled 1cm in coming to rest), calculate the average force exerted by the ground in stopping the block.
a) weight = mass x gravity
b) i) s = ut + 0.5at^2
ii) v = u + at
c) ?
a) weight = 300x9.81 = 2943N down
b) i) 3 = 0.5 x 9.81 x t^2 t = 0.78s
ii) v = 9.81 x 0.78 = 7.65m/s down
c) no idea
Work done against the block = change in gravitational potential energy of the block.
(Conservation of energy)
work done = potential energy
w = m.g.h
w = 300x9.81x3
w = 8829 joules
is that right?
w = m.g.h
w = 300x9.81x3
w = 8829 joules
is that right?
Right, so if you have the work done on the block. How would you find the force if you are given the distance?
work = force x displacement
foce = 8829/3
force = 2943N
foce = 8829/3
force = 2943N
The block travels 1cm before coming to rest.
ride4life said:
2943 x 0.01?
the unit of 2943 x 0.01 is not Newton (the question is about force)
rock.freak667 talked about what the force is if the block traveled 1 cm with some amount of work done.
What is the unit of force?
ride4life said:
2943 x 0.01?
will the unit of this calculation be Newton?
Newton seconds?
lol
yes it's Newton seconds and that's unit of momentum, not force.
Since the question is about force, no doubt the answer is wrong.
you have the distance and work, find F
Looks good.
I recommend getting in the habit of including units during your calculations, and not just sticking them on at the end. Including units should help you understand better what's going on, and will help you catch errors like thinking that "2943 x 0.01" represents a force.
Redbelly98 said:
Looks good.
Ok, thanks for the advice! :biggrin:
