Calculating Average Pressure for Tank Thrust
  • Thread starter Thread starter Parsifal1
    Average Pressure
The average pressure for calculating horizontal thrust on an oil tank is determined using the formula Average Pressure = (ρgh)/2, where ρ is the density of the liquid, g is the acceleration due to gravity, and h is the height of the liquid column. The pressure varies linearly from zero at the surface to a maximum value at the bottom of the tank. The resultant force acts at a distance of h/3 from the bottom of the wall, corresponding to the centroid of the pressure distribution triangle. This method provides a clear approach to calculating thrust based on fluid mechanics principles.
  • Understanding of fluid mechanics principles
  • Knowledge of pressure calculations in liquids
  • Familiarity with the concept of centroids in geometry
  • Basic understanding of force distribution in structural engineering
  • Research fluid statics and pressure distribution in liquids
  • Study the concept of centroids and their applications in engineering
  • Learn about the derivation of pressure formulas in fluid mechanics
  • Explore applications of resultant forces in structural analysis
Engineers, particularly those in civil and mechanical fields, students studying fluid mechanics, and professionals involved in the design and analysis of tanks and pressure vessels.
Parsifal1
I need to work out average pressure in order to work out horizontal thrust on an oil tank. I know that pressure=density*height*acceleration, although I want to know what 'top' and 'bottom' surfaces refer to. There is a tank filled with liquid, to a given depth and the height of the tank is given. So how do I work out the average pressure? Do I just sub in the to heights? The depth of the liquid and the height of the tank?
Thanks.
I meant add them together and divide by to, not sub in two pgh.
Since the pressure linearly increases with height, and the pressure at the top of the fluid is zero, the average pressure is half the maximum pressure (see link). The resultant force occurs at 1/3 the height of the tank, acting at the centroid of the "force triangle" which describes the pressure as a function of height.
http://www.savannahstate.edu/cost/eng-tech/faculty/jayjan2010/jay/hehslidec2.htm
SavannahState.edu said:
The pressure will vary from zero at the surface to (r g h) at the bottom of the wall. The pressure distribution (varying linearly with depth) will be as shown in figure above.
The total resultant force per unit length of wall = average pressure x area = pavg x h x 1
Average pressure = (r g h)/2
Therefore, Resultant force = F = (r g h)/2 x h x 1 = 1/2 {r g h2}
The resultant force acts perpendicular to the wall at the centroid of the pressure distribution triangle, at a distance of h/3 from the bottom of the wall.
  • · Replies 26 ·
