Averaging 4-fermion interactions over a fermion background
1 reply · 2K views
parton
Hi!
I have a little problem.
Consider a 4-fermion interaction (neglecting constant factors) of the form [itex]\overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{b \mathrm{L}} \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{d \mathrm{L}}[/itex] .
I want to average this interaction over a background consisting of fermions (so it corresponds to the situation where fermions propagate in a background consisting of fermions).
To this purpose, the left-handed current [itex]\overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{b \mathrm{L}}[/itex] is approximated by the average value [itex]\langle \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{b \mathrm{L}} \rangle[/itex]
There is the following relation for the averaged value produced by this interaction:
[tex] \begin{align}<br /> \begin{split}<br /> \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{b \mathrm{L}} \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{d \mathrm{L}} \to & \langle \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{b \mathrm{L}} \rangle \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{d \mathrm{L}} + \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{b \mathrm{L}} \langle \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{d \mathrm{L}} \rangle<br /> \\<br /> & \quad + \langle \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{d \mathrm{L}} \rangle \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{b \mathrm{L}} + \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{d \mathrm{L}} \langle \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{b \mathrm{L}} \rangle<br /> \\<br /> & \quad - \langle \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{b \mathrm{L}} \rangle \langle \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{d \mathrm{L}} \rangle - \langle \overline{\psi_{a \mathrm{L}}} \gamma^{\lambda} \psi_{d \mathrm{L}} \rangle \langle \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{b \mathrm{L}} \rangle.<br /> \end{split}<br /> \end{align}[/tex]
But I don't really understand how to obtain this relation. The first two terms look reasonable, but I don't understand the remaining ones.
Ok, the 3rd and 4th terms might correspond to an "exchange term", where fermion c and d are interchanged, because in the case where c is equal to d, we cannot distinguish between the propagating and the background fermion (on the other hand, if c is not equal to d, this exchange term should be 0). But why is there no additional minus sign, because of Fermi-Dirac statistics?
Maybe it has something to do with a Fierz transformation, where the minus sign cancels out, i.e.,
[tex]\overline{\psi}_{a \mathrm{L}} \gamma^{\lambda} \psi_{b \mathrm{L}} \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{d \mathrm{L}} = \overline{\psi}_{a \mathrm{L}} \gamma^{\lambda} \psi_{d \mathrm{L}} \overline{\psi_{c \mathrm{L}}} \gamma_{\lambda} \psi_{b \mathrm{L}}.[/tex]
And how could the last two terms be interpreted?
I hope somebody could help me understanding the relation above.
can you provide a reference for that averaging procedure.How is it defined.Also it is not Fierz reshuffling otherwise you will also get pseudoscalar and pseudovector part(apart from identity)
