Why is my calculated power output different from the expected value?
  • Context: Undergrad
  • Thread starter Thread starter Mark Sullivan
The discussion revolves around discrepancies in calculated power output from a bicycle crank, specifically comparing average power calculations based on torque and velocity measurements. Participants explore the implications of averaging methods and the effects of different chainring shapes on power readings.
  • One participant calculates average power output using average torque and velocity, arriving at 1,800 power units, but finds discrepancies when calculating power for individual samples, leading to values of 1,760 and 1,840 power units.
  • Another participant notes that the product of averages does not equal the average of products, suggesting a misunderstanding in the averaging process.
  • A further explanation highlights that the calculation does not account for the duration of each time sample, indicating that simply averaging values can lead to incorrect results.
  • One participant raises a broader question about the impact of elliptical versus round chainrings on power readings, expressing a preference for the idea that work is work regardless of chainring shape, but acknowledges the strength of counterarguments.
  • There is a suggestion to start a new thread to further explore the topic of power meters and chainring shapes, with a preference for the mechanical engineering forum.
Participants express uncertainty regarding the correct method for calculating power output and the implications of different chainring designs on power measurements. Multiple competing views remain, particularly regarding the effects of averaging methods and the nature of work in relation to chainring shape.
Discussions include unresolved assumptions about the averaging process and its application to power calculations, as well as the dependence on definitions of work and power in the context of bicycle mechanics.
Mark Sullivan
> Average velocity = 60rpm
> Average torque = (10 + 50 + 10 + 50) / 4 = 30TU=
> Power = 60rpm x 30TU = 1,800 power units
> However, if you calculate the power for each time sample (hence account for the different velocity recorded during each sample), then:
> Power = (62x10 + 58x50 + 62x10 + 58x50) / 4 = 1,760 power units
Help me get my head around this. I know the first is correct for power around an axis. The second is incorrect and is 40 power units under. If I do this Power = (58x10 + 62x50 + 58x10 + 62x50)/4 = 1,840 power units or 40 over. So why? It feels like the reason is just at the edge of my brain. Somewhere in school I must have learned the answer.
Mathematics news on Phys.org
The product of the averages is not, in general, equal to the average of the products.
The calculation just above is not a weighted average. It doesn't take into account the different times for each sample, but instead just divides by the number of time intervals.
Taking the average of a bunch of averages doesn't produce correct results. To see why this is true, there's an old math problem that says it's 1 mile to the top of a hill. If you average 30 mph on the trip up, how fast must you go back down the hill to average 60mph for the entire trip?
The intuitive answer (which is wrong) is that the downhill trip should be 90 mph.
Thanks, I did know that.
I am confused about a larger question that this is part of and I can't figure out which is right. It involves measuring power on a bicycle at the crank and whether elliptical or non round chain rings actually overweight/underweight a power reading when a crank speed is measured only once per revolution or non round chain rings are just an increase/decrease in the lever and well work is work and it is coming from your foot on the pedal which is on a circular radius. I lean to the latter but the counter argument is very good of which the above is part of it.
I guess I should start another thread but which forum physics or mechanical engineering?
Thanks
I lean toward mechanical engineering.
Thanks, I started the thread to mechanical engineering as "Bicycle Crank Power Meters and Round and Non-Round Chainrings" in case anyone reading this thread is interested.
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 76 ·
