Balance of forces for two charged spheres hanging from the ceiling
The discussion revolves around the balance of forces acting on two charged spheres hanging from the ceiling, focusing on the implications of their electric charges and masses. Participants explore the conditions under which the spheres maintain equilibrium, particularly considering Newton's laws and Coulomb's law.
  • Participants discuss whether the charges on the spheres need to be equal and how mass affects the balance of forces. Questions arise about the implications of assuming massless charges and whether the masses of the spheres must be identical for equilibrium.
The conversation is ongoing, with various interpretations of the relationship between mass and charge being explored. Some participants suggest that the charges do not need to be equal, while others emphasize the importance of mass equality for equilibrium. Guidance has been offered regarding the application of Newton's third law and Coulomb's law, but no consensus has been reached.
Participants are navigating assumptions about the mass of charged particles and the effects of charge on mass. There is also a mention of typical constraints in physics problems, such as the use of massless ropes and the absence of external forces.
MatinSAR
I know that in order for the ropes to have an equal angle as shown in the figure below, the weight of the two balls and the sign of the electric charge must be the same.
But how about the amount of charge?
F=kqQ/(r^2)
I think if we don't consider electron's/proton's mass then we can say that the amount of charge doesn't need to be equal according to Newton's 3rd Law. I mean having q on one ball and 2q on another ball , still makes the angles having the same size. Is it true ?
What if we consider proton's mass(or electron's mass) ???
I think both balls should have same amount of electric charge and number of protons(electrons)on each ball should be equal.
If I understand you, you are concerned about the change in mass resulting from the charge that a ball may be holding.
The givens are that the ropes are at equal angles and there is no other force applied to the balls (for example, between a ball and the ceiling).
If there is no other context to this question, I would explicitly invoke massless electrons - from the same source as the massless ropes commonly used in problems such as these - or from the same source as a ceiling that applies no electrostatic force to the hanging balls.
Are you sure about the bold part? I certainly agree that the charges must have the same sign but are you sure there is no way to fiddle the mass/charge ratio so that the weights are not the same?
MatinSAR said:
Relevant Equations:: F=kqQ/(r^2)
I think if we don't consider electron's/proton's mass ...
I do not see the electron mass or the proton mass in your relevant formula.
But I don't see an expression for each of the two angles either, so I wonder how you can make any statements at all ?
MatinSAR said:
Homework Statement:: I know that in order for the ropes to have an equal angle as shown in the figure below, the weight of the two balls and the sign of the electric charge must be the same.
Consider two facts that you must already be familiar with.
  1. For the two masses to hang in equilibrium, their center of mass must be below the level of support.
  2. The force that charge A exerts on charge B has the same magnitude and opposite direction to the force that B exerts on A.
Put the two together.
Good idea. Thank you for your time.
I think they should have similar mass.
I said the charges should have same sign because otherwise they will get closer.
And I said they should have equal mass because of above image.
I was not sure about the amount of charge on each ball ...
Thank you but I haven't read about number one before ...
Can't we find out if amount of electric charge on each ball should be the same or not without fact number 1?
So, you've moved from identical mass to "similar" mass. Even for that, I have to ask ... why?
What is the difference ???
?? You don't understand the difference between "identical" and "similar"
I mean m1=m2 ...
Hello @MatinSAR. I follow your work shown in green in your figure of post #6. Can you state your reasoning for writing the purple equation ##F \cot \theta = F' \cot \theta##? I think you're probably thinking correctly and you're getting this equation from something you mentioned in your first post. But please confirm how you got the purple equation.
You were also asking whether the two charges had to have the same magnitude. You should be able to answer this by inspecting Coulomb's law.
As @.Scott mentioned, changing the charge of a ball does not change the mass of the ball by any significant amount.
MatinSAR said:
I mean m1=m2 ...
Which is not necessary for this problem --- that's what I'm trying to get you to see.
Hello. Because of Newton's 3rd law F should be equal to F'.
I think it's not necessary because of the fact that F12=F21.
So mass of the balls should be the same and the charges should have same sign ...
And it is not necessary to have same amount of charge on each ball.
Is it true?
Can you tell me why ?!
Here #6 I have proved that the mass of two balls should be equal.(m1= m2)
No, you did not. You proved that if you assume the charges are identical then the masses have to be identical. That is a vacuous truth. Please THINK about the problem. You clearly did not think through post #3.
Yes. The 3rd law is the basis for your purple equation.
OK. But, also, the electric force depends on the charges as the product of the charges. So, the electric force will not change if you change the individual charges such that their product remains the same.
Is it true?
Yes.
Thank you for your help and time. I'll spend more time on it tomorrow morning ... perhaps I will understand what were you trying to tell me ... 🙏
TSny said:
Yes. The 3rd law is the basis for your purple equation.OK. But, also, the electric force depends on the charges as the product of the charges. So, the electric force will not change if you change the individual charges such that their product remains the same.Yes.
I have understand it completely.
Thanks a lot for your time.
No, the assumption made in post #6 is that the electrostatic forces are equal and opposite. Seems fair.
Good point. I was thinking about it incorrectly.
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 21 ·
