Ball on a string with initial velocity
A ball with a mass of 1.72 kg is attached to a peg with a 1.54 m string and released from a vertical position with an initial speed of 4.81 m/s. The problem involves calculating the ball's speed when the string makes a 21.7° angle above the positive X-axis using energy conservation principles. The initial attempts to solve the equation contained errors, particularly in the use of sine and the absence of a necessary factor of 2. After correcting these mistakes, the final calculation yielded a speed of approximately 6.49 m/s, which is the correct answer. The discussion highlights the importance of careful attention to detail in physics calculations.
joe_coolish
A ball with mass m = 1.72 kg is attached to a peg at the origin using a length of massless string of L = 1.54 m. It is released from the top of a vertical circle with speed v0 = 4.81 m/s. What is the ball’s speed (m/s) when the string makes an angle θ = 21.7° above the positive X axis?
Kf+Uf = Ki+Ui
K=0.5mv^2
U=mgy
I started by using Kf+Uf = Ki+Ui => .5mVi^2 + lmg = .5mVf^2 + lsinθmg
and then I solved for Vf:
Vf=SQRT(Vi^2 + lg - lsinθg)
that came out to be 5.71, but the correct answer is 6.49. Any help would be wonderful!
joe_coolish said:
I started by using Kf+Uf = Ki+Ui => .5mVi^2 + lmg = .5mVf^2 + lcosθmg
Hi joe_coolish, welcome to PF! :smile:
You've used the cosine, while you should have used the sine.
Thank you for your reply and for the welcome!
I changed the formula to Vf=SQRT(Vi^2 + lg(1 - sinθ))
which gave me this: SQRT(4.81^2+(1.54*9.8)*(1-SIN(RADIANS(21.7)))) = 5.713832509
(I like to use EXCEL for these things)
Which was my original answer. Sorry, I must have copied it down wrong :) I'll edit my original post.
But still, that is the wrong answer... Am I missing something?
In your original equation you have a factor 0.5.
In your final equation there should be a corresponding factor 2 somewhere...
(And yes, Excel is the perfect tool for things like this. :smile:)
Ah! I need to lay off the late nighters...
Thank you!
SQRT(4.81^2+(2*1.54*9.8)*(1-(SIN(RADIANS(21.7))))) = 6.493047349
It's always that dang 2!
Thank you!
Yep! :smile:
Uhh, sometimes it's a dang minus sign! :)
  • · Replies 29 ·
26K
