Why is the most common base 10?
  • Context: High School
  • Thread starter Thread starter manlyman62
    Base
The discussion revolves around the reasons for the prevalence of base 10 in numeral systems, exploring historical and cultural contexts, as well as alternative bases like 12, 20, and 60. Participants also touch on modern bases such as binary, octal, and hexadecimal, and consider the implications of counting systems.
  • Some participants suggest that base 10 is common due to counting fingers and thumbs, while others note that other bases like 12 and 20 have practical advantages in divisibility.
  • Base 12 is highlighted for its divisibility by multiple factors, making it convenient for certain applications, such as measuring and counting.
  • Base 20 is mentioned as being related to counting both fingers and toes, with cultural references like the French word for 80 supporting this idea.
  • Base 60 is noted for its historical significance in timekeeping and geometry, with roots in Babylonian counting systems.
  • Modern bases such as binary (base 2), octal (base 8), and hexadecimal (base 16) are discussed in the context of computer technology.
  • Some participants propose that base 6 could be a more natural fit based on hand counting, while others argue that it is less common in natural languages compared to base 10 and others.
  • There is a discussion about base 1, with differing opinions on its validity as a numeral system compared to other bases.
  • Participants express uncertainty about the implications of using different bases and the significance of symbols in numeral systems.
Participants express a range of views on the significance and practicality of different bases, with no consensus reached on the superiority or appropriateness of any particular base. Disagreements arise particularly around the concept of base 1 and its classification as a numeral system.
Some claims about the advantages of certain bases depend on cultural practices and historical contexts, which may not be universally applicable. The discussion also reveals varying interpretations of what constitutes a valid numeral system.
manlyman62
Hello! I was just wondering why the most common base is base 10? It seems kind of arbitrary to me, although I may be overlooking something.
Mathematics news on Phys.org
Counting your thumbs, how many fingers do you have?
Haha! Duh! Ok, thanks!
Other bases have been used over time, such as 12, 20, 60, 360.
Base 12 is convenient to use because it can be divided evenly by 2, 3, 4, and 6, so many fractional amounts of 12 things come out as whole numbers. We buy eggs by the dozen and count (in the US) 12 inches to the foot. A gross of things is 144 of them, or 12 dozen.
Base 20 is nearly as obvious as base 10 (counting toes and fingers). I believe that the French word for 80, quatre vingt (4 twenty), might be a remnant of base-20 counting.
Base 60 is still present in the number of seconds in a minute or minutes in an hour or degree. 60 has the advantage of being divisible by 10 or 20 as well as 12.
Base 360 - the number of degrees in a full circle. If my memory is correct, the Babylonians counted numbers using this base.
Other bases -- base 2, base 8, base 16 -- are more modern, and stem from computer technology, with transistors able to attain one of two possible states. A single bit in memory can be either 1 or 0, corresponding in some way to a high voltage or a low voltage. The binary digits are 0 and 1.
If you collect three bits together, you can represent any of eight numbers: 0, 1, 2, 3, 4, 5, 6, or 7, the octal digits. If you collect four bits together, you can represent any of 16 different numbers: 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, A, B, C, D, E, F. These are the hexadecimal digits.
I always knew there was something a little funny about the French
This is the prevailing answer, but it always leaves me unsatisfied. Personally, I think base 6 is the better match: the right hand is the 1s place, and the left hand is the 6s place.
80 is quatrevingt (4 twenties, or 4x20). 60 is soixante. & I think another common base is hexadecimal (base 16) & I guess there's binary also (base 2), but everyone knows about that one
Mark44 said:
Base 20 is nearly as obvious as base 10 (counting toes and fingers). I believe that the French word for 60, quatre vingt (4 twenty), might be a remnant of base-20 counting.
I wonder if any societies have ever had a base 21 counting system... :rolleyes:
I have read that the Kwakiutle Indians of the Pacific north west counted using the spaces between the fingers. Although their's was not a "place value" numeration system, it was based on "4" rather than "5" or "10".
Apparently the Mayans had a base 20 system
I feel like by the time placeholders were invented, either a base was set already or a base was picked on needs other than the ability to count on your hand
Base 6 is extremely uncommon, though -- base 10, base 20, base 5, base 100, base 12, base 60, and base 4 are all more common in natural languages. Actually, I can't think of a single example.
When I want to hide a number in plain sight I use base 9 but then add random 9's and simply ignore them.
I don't know of any examples either; it just seems natural to me. Of course, I'm looking at this in hindsight with zero and place value at my disposal.
That's a fantastic idea! Do you do the conversion in your head? With octal you could just use a calculator...
The real reason is if a number is in any base it's in base 10.
What does this mean? Are you speaking binary?
Binary, ternary, hex - whatever. If you store the binary number base (two) and print it out in binary it comes out as 10. If you store the hex number base (sixteen) and print it out in hex it comes out as 10. Same for any other base. The base is always 10.
Binary, ternary, hex - whatever. If you store the binary number base (two) and print it out in binary it comes out as 10. If you store the hex number base (sixteen) in binary and print it out in hex it comes out as 10. Same for any other base. The base is always 10.
Heh. I'd never thought of it that way.
There is, of course, a single exception - and a commonly used one at that (people use it a lot when playing cards): base 1.
i.e.:
Base 1 is simply: base 1.
I don't think counting by tickmarks really counts as "base 1." Base 1 doesn't follow the consistent pattern that is present in other bases such as base 2, 3, 8, 10, 16, etc. In base 2, there are 2 binary digits, 0 and 1. In base 3, there are three ternary digits, 0, 1, and 2. If we're counting in base a, the digits go from 0 up through a - 1.
Following the same logic, in base 1, the only digit would be 0, which makes counting pretty difficult.
That's not the pattern though. You're looking a the wrong part for significance.
We use 0 and 1 by convention as the first two symbols in our numeral system. In base 1, we can use tickmarks, but it doesn't matter what the symbol is as long as we know what it represents - which is why it can just as easily be 1 - or 0.
The important pattern this:
- we start counting with our list of symbols
- when we use up all our symbols we start a new column, and resume counting
So:
base 3:
0,1,2, (add a new column, keep going) 10,11,12,20,21,22, (new column) 100, etc.
Here it is with different symbols:
a,b,c,ba,bb,bc,ca,cb,cc, baa, etc.
base 2:
0,1 (add a new column, keep going) 10,11, (again) 100,101, etc.
Again, with different symbols:
a,b,ba,bb,baa,bab, etc.
base 1:
1, (add a new column, keep going) 11, (again), 111, etc.
a, aa, aaa, etc.
I disagree, Dave.
Base 3 digits
0,1,2
Base 2 digits
0,1
Base 1 digits
In base b, the contributed numerical value of a digit x, in the nth column is the x n^b. The range of x is (0,1,2,...,b-1).
It would break with established pattern to use one instead of zero for the digit set for base one.
Phrak said:
I disagree, Dave.
Base 3 digits
0,1,2
Base 2 digits
0,1
Base 1 digits
You don't have to use the numerical symbols 1,2,3. You can use any symbols, as long as you keep them in order. The problem here, is the confusion between the symbols 1,2,3 and the counting numbers 1,2,3.
No, I don't have that confusion. Using the standard symbols, so we all know what we're talking about, base 1 can represent only zero, and no higher.
Zero in all the bases is a way of representing "no unit here". When you want to to start counting, you add your first symbol to that column. Another way of representing "no unit here" is to leave the column blank.
The key to bases is this: how many symbols can you use before you have to add another column to continue counting?
In base 2, you can count exactly 2 things before you need another column; in base 1 you can count exactly one thing before you need another column.
Regardless of where you see a deviation, it's still valid.
An analogy: By your logic, you would be claiming that the first prime number is 3 (the pattern you see is that prime numbers must be odd, therefore 2 is out).
But it isn't; the first prime is 2. 2 is a unique prime in that it breaks some common symmetry of prime numbers (being even), but it does not break the critical rule that truly defines prime: it is divisble only by 1 and itself. 2 fits, no matter how exceptional it is.
In base 2 when you get to the second object you need a new column to represent it, so in base1 you need a new column to represent the first object. In base 2 you need a third column to represent 22 objects, so in base 1 you need a third column to represent 12 objects.
To make a long story short, you need infinite columns to represent the number 1
DaveC426913 said:
Zero in all the bases is a way of represeting "no unit here". When you want to to start counting, you add your first symbol to that column. Another way ofr representing the same things is to leave it blank.
OK. We use your notion that a base N can count N things in the first column. So the first digit in base 1 can represent one thing. There would be ten symbols in base 10 representing counts from one to ten.
Continuing this pattern, the first symbol in base 2 represents one thing or two things. How would you respresent numbers of higher basis in this modified system?
It can represent one (1) thing or no (0) thing.
Note that this occurs with zeroes in embedded columns (such as 101), not leading zeroes. Base 1 has no embedded zeroes.
And like all other bases, base 1 does not use symbols for leading zeros, it just uses blank.
I did start the discusion by stating that base 1 is exceptional, so there's no contention there, but exceptional doesn't mean something is disqualified (see prime numbers, above).
You're protesting details, but I think you're missing the forest for the trees.
Any number that can be counted using 2 or 6 or 10 symbols, you can just as easily count using only one symbol. You simply follow the exact same procudure:
- Count using all the symbols available to you until you run out of symbols.
- Add a new column to the left, containing your lowest symbol, then iterate through all your symbols again.
- Repeat as needed.
The only way base 1 is exceptional is that it does not happen to have zero as one of its symbols. It doesn't need it - it starts with blank in its leading column (like all other bases do).
- Repeat as needed.
This seems to be a good enough system to respresent elements of an ordered set set, as counting numbers do, but in the system of the basis respresentations of numbers it can only represent one number without having a symbol for zero and at least one other, or three, if we count blankspace as delimiters.
Hmm, interesting thought, why are arabic numerals automatically the standard symbols?
Which ones did you mean?
These: 0123456789?
Perhaps these: ٠١٢٣٤٥٦٧٨٩?
  • · Replies 44 ·
  • · Replies 105 ·
12K
18K
  • · Replies 16 ·
