How Does the Early Effect Influence Base Current in a Transistor?
The Early effect describes how the collector current in a common emitter circuit increases with higher collector-emitter voltage due to base-width modulation. It does not directly alter the base current; instead, it influences the transistor's forward gain. Changes in forward gain can subsequently affect the base and collector currents indirectly. Understanding this mechanism is crucial for analyzing transistor behavior in circuits. The relationship between the Early effect and current dynamics highlights the complexity of transistor operation.
sahil_time
Early effect states the collector current increases as we increase CE voltage in a common emmiter circuit due to base-width modulation. But how does the Early effect change the base current? Does base current remain constant or does it change?
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 60 ·
16K
