Basic Electronics True or False Questions
12 replies · 4K views · last reply
Femme_physics
I also needed to explain my answer... I hope it's all true. Can you tell me?True or False
The Effective Voltage in our houses (Israel) is 220 Volts, therefor the Max VOltage is 380 Volts.
FALSE
220[itex]\sqrt[]{}2[/itex] = 311
The equivalent inductance between points AB in the following circuit is 90 mh.
http://img824.imageshack.us/img824/3699/coils.jpg FALSE, due to the calculations I made in the pic.
The Duty Cycle of the final repeating signal is 66.66%.
http://img545.imageshack.us/img545/570/31464876.jpg
True.
4/6 = 66.66%
In a rectification circuit of an AC sinusoidal voltage with the help of a single diode we get the following wave form after rectification.
http://img197.imageshack.us/img197/8518/booep.jpg
FALSE. You need 4 diodes for rectification such as in a Diode Bridge.
The conductance of resistor R in the following circuit is 10 Mho.
http://img705.imageshack.us/img705/4672/dadamn.jpg
FALSE
G = 1/100 = 0.01 Mho
The Frequency of the following repeating signal is 6 Kilohertz.
http://img825.imageshack.us/img825/4918/xttx.jpg
FALSE
f = 1/6
omega = 2pif = 2 x pi x 1/6 = 1.047 Hertz
Femme_physics said:
In a rectification circuit of an AC sinusoidal[/color] voltage with the help of a single diode we get the following wave form after rectification.
Actually, you can use a single diode for rectification. You get what's called half-wave rectification (effectively chopping off the lower or upper half of the waveform, depending upon the diode's direction).
https://www.physicsforums.com/attachment.php?attachmentid=41007&stc=1&d=1321554469
The real problem here is fact that the shown resulting waveform does not resemble a sinewave nor any part of one.
It's perfectly possible to rectify an AC voltage with only a single diode, it just isn't very efficient. What do you think is the waveform that is produced, if you put an ac voltage source in series with a diode?
The frequency of a signal is 1/period. [itex]2 \pi[/itex] doesn't come into it. I think you're confused with the angular frequency.
I agree with the other responses. You get this rectified voltage with 1 diode.
The frequency =1/T = 1/6x10^-3 =167Hz (the time scale is in milliseconds)
Cheers
Cheers
Again, made a mistake :smile: The question is if I can rectify to THIS
With just one diode.
technician said:
that is what you get with 4 diodes!
Yes, that's what I meant. I just posted the wrong pic. :smile: There you go! Thanks.
So was I right about everything?
The frequency question is wrong because the time scale is in ms (millisecs) and the time for 1 cycle (T) is 6 x 10^-3s.
The frequency =1/6x10^-3
1/6x10^-3 = 166.6667 hertz
So the answer is 0.16 kilohertz and not 6 kilohertz. Therefor the answer is still "FALSE", correct?
You rock, technician! Thanks a bunch.
Thanks a lot... can't wait to see what you come up with next!
