Basic parallelization technique for computing ensemble's average
  • Thread starter Thread starter Llewlyn
    Average Computing
Llewlyn
Hi there,
as much of you i possesses a notebook (ubuntu) with DualCore processor. When i write my scientific simulation (C/C++ usually) i don't mind parallelizzation at all, that is, my program works on a single core only. I want to get benefit from dualcore technology without being crazy with OpenMP or other parallelizzation computing tools so i ask:
How may i use both core in our simulations in a "simple" way?
The first naive technique that comes to mind is to launch a fork, splitting process in two different thread and let the kernel does the dirty job. A more sophisticated technique is to use OpenMP and trying to do some basic naive paralleling, take for instance the evaluation of an ensemble's average: I run 500 temporal simulation and then averaging, i may split 250 simulation on one core and the rest 250 on the other. Should it works? Any experience?
Ll.
Hello Ll.,
Thank you for your question. Utilizing both cores in your simulations can definitely improve performance and speed up your scientific work. There are a few different ways you can approach this, depending on your specific needs and programming experience.
One option is to use OpenMP, as you mentioned. This is a popular and effective tool for parallelizing code and utilizing multiple cores. It allows you to easily distribute tasks among the cores and handle synchronization between them. There are many resources available online for learning how to use OpenMP in your C/C++ code, so I won't go into too much detail here. But I will say that it's a good idea to start with small, simple parallelization tasks and gradually increase the complexity as you become more comfortable with the tool.
Another option is to use a library specifically designed for scientific computing, such as MPI (Message Passing Interface). This is a more low-level approach compared to OpenMP, but it can also provide more control over how your code is executed in parallel. With MPI, you can distribute tasks among multiple cores or even multiple machines, allowing for even greater performance gains. Again, there are many resources available for learning how to use MPI, so I would recommend doing some research and finding a tutorial or guide that works best for you.
Finally, as you mentioned, you can also use the fork system call to create multiple processes and distribute the workload among them. While this may seem like a simple and straightforward solution, it can actually be quite complex to implement and manage. Additionally, it may not provide as much control over the parallelization process compared to using a tool like OpenMP or MPI. However, if you are comfortable with this approach and it works well for your specific needs, then there is no reason not to use it.
In summary, there are multiple ways to utilize both cores in your simulations, and the best approach for you will depend on your specific needs and programming experience. I would recommend experimenting with different tools and techniques to see what works best for you. And as always, don't hesitate to seek out resources and ask for help if you run into any issues. Good luck!
