Basic question regarding logical implications
  • Context: High School
  • Thread starter Thread starter Serious Max
The discussion revolves around the logical implications of three statements regarding taking a shower based on the temperature of the water. Participants explore the meanings and interpretations of these statements, focusing on their logical structure and implications.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants propose interpretations of the statements, suggesting that (1) implies taking a shower if the water is warm, (2) implies taking a shower unless the water is cold, and (3) suggests a possibility of taking a shower if the water is warm.
  • Others argue that (2) implies that if the water is cold, then a shower will not be taken, and (3) suggests that if the water is not warm, a shower will definitely not be taken.
  • A later reply questions the meaningfulness of saying "I might decide to take a shower," suggesting that this does not provide clear information.
  • Some participants discuss the nuances of the terms "if," "only if," and "unless," with one noting that "unless" does not have a consistent translation in symbolic logic.
  • There is a mention of the linguistic differences between "unless" and "not ... unless," indicating that the latter introduces necessary conditions for the outcome.
Participants express differing interpretations of the statements, with no consensus reached on their meanings or implications. The discussion remains unresolved regarding the precise logical translations and implications of the statements.
Participants highlight the complexity of translating natural language statements into formal logic, noting that certain phrases may introduce ambiguity or require careful interpretation.
Serious Max
Three statements:
1) I will take a shower if the water is warm.
2) I will take a shower unless the water is cold.
3) I will not take a shower unless the water is warm.
How different are their meanings?
First guess was:
1) water is warm => I take a shower
2) water is not cold = water is warm => I take a shower
3) water is warm => I could take a shower
Although, I suspect the second one doesn't mean warm, just not cold (could be cool for example). So it's a statement on its own.
So:
2) water is not cold => I take a shower
It seems to me that you're not translating (2) and (3) correctly. For example, (2) also says that if the water is cold, then you will not take a shower (well, it's debatable whether it says this, but to me the sentence does imply it).
And (3) says that if the water if not warm, then you will definitely not take a shower. This is missing from your translations.
Correct
OK, but what if the water IS cold? The statement does imply what happens in this case too.
We wouldn't normally say this - "I could take a shower" means "either I take a shower or I do not take a shower" which doesn't tell us anything. However what if the water is NOT warm? The statement has a more meaningful implication then.
Micromass beat me to it.
That makes 2 - 1 then :-p
Thanks.
So should it be along the lines of:
2) water is not cold (warm, cool etc) => I take a shower; otherwise, if the water is cold, I will not take a shower
3) water is warm => I might decide to take a shower; otherwise, if the water is not warm (cold, cool etc), I will definitely not take a shower
maxpancho said:
Thanks.
Can you state this briefly? Use iff.
Like MrAnchovy remarked, a thing like "I might decide" isn't really meaningful. To be fair, you could interpret the third sentence in a lot of way. But I interpret it that if the water is warm, then I definitely will take a shower. It is debatable though.
micromass said:
... I interpret it that if the water is warm, then I definitely will take a shower...
No I don't think you can conclude anything if the water is warm, I liked your previous interpretation better:
micromass said:
... if the water if not warm, then you will definitely not take a shower.
p water warm
w water not cold
q take a shower
1) p ## \rightarrow ## q
2) w ## \leftrightarrow ## q
3) p ## \leftarrow ## q ("if the water is not warm, then you will definitely not take a shower" = if I'm taking a shower, then you can be sure the water is warm, but that doesn't mean that if the water is warm I will definitely take a shower)
So, as I understand,
"If" expresses one of the many criteria for something to be done for certain (although, we don't know how many there are, it might be that this critertion is the only one, or maybe there are multiple). And "only if" merely gives restrictions, as to when something CAN be done, but not necessarily will be done.
"If and only if" is the same, in essence, as "only if" combined with "if", that is — we have a restriction that should be satisfied, and it is indeed satisfied. Hence now what was specified HAS to be done.
only if ## \subseteq## if ## = ## if and only if
maxpancho said:
p water warm
w water not cold
q take a shower
2) w ## \leftarrow ## q
3) p ## \leftarrow ## q (if the water is not warm, then you will definitely not take a shower)
But unlike "if and only if" I don't think the word "unless" has a consistent translation into symbolic logic.
In the phrase "I will take a shower unless the water is cold", the phrase "I will (outcome) unless (proposition)" introduces a necessary and sufficient condition (that the proposition is false i.e. "the water is not cold") to the outcome "(I will) take a shower".
When we see "I will not take a shower unless the water is warm", we are tempted to parse this in the same way so that the outcome is "(I will) not take a shower". But I do not believe this is linguistically correct; the correct parsing is "I will not (outcome) unless (proposition)", with the subtle difference that the condition (that the proposition is true i.e. "the water is warm") is necessary (for the outcome i.e. "(I will) take a shower") but no longer sufficient.
I re-edited my post a few times :) But you seem to have commented an earlier version.
Of course this has nothing to do with mathematical logic, it is linguistics. In mathematical logic we define things precisely so that when we write A → B ("A implies B") it is clear that this means that if A is true then B is also true, but if A is false we don't know anything about B.
Ah yes, I like the new version better - it illustrates the linguistic difference between "unless" and "not ... unless" well.
  • · Replies 66 ·
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 32 ·
