Time Derivative of Trigonometric Functions in Polar Coordinates
  • Thread starter Thread starter Cosmophile
The discussion focuses on finding the velocity in polar coordinates using the Kleppner/Kolenkow text. The user initially struggles with taking the time derivative of trigonometric functions like sine and cosine, mistakenly thinking they are not time-dependent. However, it is clarified that these functions do depend on time when the angle theta changes. The conversation emphasizes the importance of including unit vectors in calculations and converting Cartesian components into polar coordinates. Ultimately, the user successfully derives the velocity expression in polar coordinates, enhancing their understanding of the topic.
Cosmophile
I'm attempting to find velocity in polar coordinates (Kleppner/Kolenkow text). What I've got is:
\vec{v} = \frac {d}{dt} (x \hat{i} + y \hat{j})
= \frac {d}{dt} (rcos \theta) + \frac {d}{dt} (rsin \theta)
= r \frac {d}{dt} (cos \theta) + cos \theta \frac {d}{dt} (r) + r \frac {d}{dt} (sin \theta) + sin \theta \frac {d}{dt} (r)
From here on, I get stuck. How do I take the time derivative of sin \theta or other trig functions whose subject is not time? So far, I've got this:
-r \dot {\theta} sin \theta + \dot{r}cos \theta + r \dot{\theta} cos \theta + \dot{r} sin \theta
That being said, I also have a thought that the time-derivative of, say, sin \theta would be zero, because sin(theta) is not dependent upon time. Though, I may be wrong. (Which is entirely why I'm asking here!)
Thanks in advance!
(Also, there is the obvious grouping to be done on the 5th line of LaTeX)
What happened to i and j ? You need to keep two cartesian components in this calculation. Then express the resulting cartesian vector in polar coordinates.
It does depend on time when \theta does.
Alright! I'll work with it and post when I think I've got something. Thanks!
I very much liked the presentation here. It took me an awful long time to reproduce the expressions for the straight line motion example (page 4,5)
Alright! I've got it. All I needed was to remember to include my unit vectors (beginner's mistake, I hope), and an identity derived from the geometry of polar coordinates:
\vec {r} = (x \hat{i} )
Nope, ##\vec r = x\hat\imath+y\hat\jmath## !
To work out your ##\vec v## in the way you started, you need to convert ##\hat\imath## and ##\hat \jmath## to polar coordinates too. Do you have those expressions ?
(Hint: Think of a simple rotation to go from ##\hat\imath,\;\hat \jmath## to ##\hat r,\;\hat \theta## and the inverse rotation (= over minus same angle) to go the other way).
Very instructive to see how only two terms emerge from a rather long expression !
That post was actually accidentally posted prematurely; I'm working on the full one right now, haha.
Happens to me all the time: pressing that button too early. They do have an edit button on the left, but sometimes doing that only increases confusion and creates misunderstandings
Alright! I think I've got it. All I needed was to remember to include my unit vectors (beginner's mistake, I hope), and some identities derived from the geometry of polar coordinates:
\vec {r} = (x \hat\imath + y \hat\jmath )
\frac {d \vec {r}}{dt} = \frac {d}{dt} (x \hat\imath + y \hat\jmath)
x = r cos \theta \hat\imath and y = r sin \theta \hat\jmath
Thus, \frac {d}{dt} [x \hat\imath + y \hat{j}] = \frac {d}{dt}(rcos \theta \hat{i} + r sin \theta \hat\jmath)
= r \frac {d}{dt} [cos \theta \hat\imath] + cos \theta \hat{i} \frac {d}{dt}(r) + r \frac {d}{dt} (sin \theta \hat\jmath) + sin \theta \hat{j} \frac {d}{dt}(r)
= r \frac {d}{dt} [cos \theta \hat\imath + sin \theta \hat\jmath] + (cos \theta \hat {i} + sin \theta \hat {j})\frac {d}{dt}[r]
= r( \frac {d}{dt}[cos \theta \hat\imath] + \frac {d}{dt}[sin \theta \hat\jmath]) + \frac {dr}{dt}(cos \theta \hat{i} + sin \theta \hat{j})
= r( \dot{ \theta} cos \theta \hat\jmath - \dot{ \theta} sin \theta \hat\imath) + \dot {r}(cos \theta \hat{i}+sin \theta \hat{j})
= r \dot{ \theta} (cos \theta \hat\jmath - sin \theta \hat\imath) + \dot {r}(cos \theta \hat{i}+sin \theta \hat\jmath)
From the geometry of polar coordinates:
(cos \theta \hat\imath - sin \theta \hat\imath) = \hat{ \theta}
(cos \theta \hat\imath+sin \theta \hat\jmath) = \hat{r}
So,
\frac {d \vec{r}}{dt} = \dot{r} \hat{r} + r \dot { \theta} \hat { \theta} = \vec {v}
Well done.
For the record: 1 typo ##(cos \theta \hat\imath - sin \theta \hat\imath) = \hat{ \theta}## should be ##(cos \theta \;\hat\jmath - sin \theta\; \hat\imath) = \hat{ \theta}## but you processed it correctly.
That probably occurred when I went back to change the tex for all of my unit vectors. I saw how you had done it in a way to get rid of the dots for the i's and j's, and probably typed it in wrong. Anyway, thank you for the help! This text is pretty rigorous, especially for someone who has taught himself the Calculus that I know, but I'm really enjoying it!
  • · Replies 20 ·
  • · Replies 19 ·
