Basis for a Plane that is given.
7 replies · 2K views · last reply
Sai-
Consider the plane 3x1-x2+2x3 = 0 in R3. Find a basis for this plane. Hint: It's not hard to find vectors in this plane.
Plane: 3x1-x2+2x3 = 0 in R3.
Let,
A = [itex]\left[3,\right.\left.-1,\right.\left.2\right][/itex] [itex]\rightarrow[/itex] [itex]\left[\frac{3}{3},\right.\left.\frac{-1}{3},\right.\left.\frac{2}{3}\right][/itex] (Row Reduced)
[itex]\Rightarrow[/itex] x1 = [itex]\frac{1}{3}[/itex]x2-[itex]\frac{2}{3}[/itex]x3, x2 is free, x3 is free.
[itex]\Rightarrow[/itex] [itex]\left\{x_2[\frac{1}{3},1,0]+x_3[\frac{-2}{3},0,1] | x_2, x_3 \in R\right\}[/itex]
[itex]\Rightarrow[/itex] Basis of Plane = [itex]\left\{[\frac{1}{3},1,0],[\frac{-2}{3},0,1]\right\}[/itex]
jedishrfu said:
you didn't take advantage of the hint. A o B = |A| |B| cos(ABangle) and in your case you've got <3,-1,2> o <x1,x2,x3> = 0
Don't I just get the plane then, because
<3,-1,2> DOT <x1,x2,x3> = 3x1-x2+2x3
which then is equal to 0.
it means that the vectors you are looking for are perpendicular to <3,-1,2>
It also means that <0,0,0> is in the plane
so what if you set x1=0 and solve for x2 and x2 then you'd have one vector and similarly set x2=0 and solve for x1 and x3 to get the other vector.
I set x1 = 0, so then -x2 + 2x3 = 0, so x2 = 2, x3 = -1 ... <0, 2, -1> = u
I set x2 = 0, so then 3x1 + 2x3 = 0, so x1 = 2, x3 = -3 ... <2, 0, -3> = v
<0, 2, -1> DOT <3, -1, 2> = 0
<2, 0, -3> DOT <3, -1, 2> = 0
So then my basis for the plane is <0, 2, -1>, <2, 0, -3>.
If this is the correct basis, then I'm wondering how come the first basis was wrong? If in my first attempt I solved the problem every other way that I do to get the basis's for other matrices.
I never said they were wrong. I just showed you how I would attack the problem using the hint that was given. In your case any two non parallel vectors in the plane can form a basis from which other vectors can be generated.
I didn't quite understand your method and saw that you didn't consider the hint. My apologies for any confusion.
Anyway, one last check you can do is to dot the basis vectors with each other to make sure they aren't parallel or anti-parallel (parallel but pointing in opposite directions).
Thank you for the feed back! I dotted my original basis's with the vector that forms the plane and got 0 for both the vectors in the basis.
Also dot them against each other as a check against them being parallel.
