Understanding Eigenvectors: Solving for Eigenvalues and Corresponding Vectors
The eigenvalues identified are λ = 0, -1, and 2, with corresponding eigenvectors (1, 1, 1), (1, 0, 1), and (1, 1, 0). The kernel of T is determined to be spanned by the vector (1, 1, 1), indicating it is one-dimensional. The range of T is spanned by the other two eigenvectors, which are linearly independent and thus span the range. It is clarified that the basis for the kernel is the vector itself, while the kernel consists of all constant multiples of this vector. The discussion concludes that the kernel and range dimensions are consistent with the properties of eigenvectors.
squenshl
Let ##\mathbb{R}^3\mapsto \mathbb{R}^3## be given by $$T\begin{pmatrix}
x \\
y \\
z
\end{pmatrix} := \begin{pmatrix}
x+y-2z \\
2x-2z \\
y-x
\end{pmatrix}.$$
1. Give a basis of eigenvectors for ##\text{ker}(T)##.
2. Give a basis of eigenvectors for ##\text{ran}(T)##.
None
Okay so I found the eigenvalues to be ##\lambda = 0,-1,2## with corresponding eigenvectors ##v =
\begin{pmatrix}
1 \\
1 \\
\end{pmatrix},
\begin{pmatrix}
1 \\
0 \\
\end{pmatrix},
\begin{pmatrix}
1 \\
1 \\
\end{pmatrix}
Not sure what to do next. Thanks!
What are ##\ker T## and ##\operatorname{im}T##?
Likes Cryo
I don't think it makes sense to talk about a basis of eigenvectors for ##\text{ker}(T)## and ##\text{ran}(T)##.
It's more usual for a problem to ask for a basis for each of these subspaces.
If ##T## is semisimple (diagonalizable) then we can find a basis of eigenvectors, in any case generalized eigenvectors. He has even calculated them already.
Ok so the kernel of ##T## is ##(x,y,z)## such that ##T(x,y,z)=0## & this only occurs when we have ## (1,1,1)## so I guess that is the basis for the kernel right?
So the basis for the range of ##T## are the other two eigenvectors.
Yes. But ##(1,1,1)## is not the only vector, all multiples are as well sent to zero. If the kernel is one dimensional, then the range is two dimensional. The other two eigenvectors are in the range. Now do they span the range? Or more generally: Are eigenvectors to distinct eigenvalues always linearly independent, and why?
Right the basis for the kernel is the span of ##(1,1,1)##. Yes eigenvectors are linearly independent so they do span the range thanks!
squenshl said:
Right the basis for the kernel is the span of (1,1,1).
A basis for the kernel is the vector <1, 1, 1>, not the span of this vector. ##\text{Ker} (T)## is the set of all constant multiples of <1, 1, 1>; i.e., the span of <1, 1, 1>.
Notice that for ##x ## the kernel ##Ax=0 = \lambda 0 ## for any ## \lambda ##
