Undergrad What is the Basis for the Null Space in Matrix A?
The discussion centers on understanding the basis for the null space of a matrix and its relationship to vector spaces. A basis for a vector space can be formed by any set of linearly independent vectors, which can be visualized as alternate axes. The participants clarify that the basis for a matrix's row space consists of linearly independent row vectors, while the basis for the column space consists of column vectors that are not scalar multiples of each other. The column space of a matrix is confirmed to be a two-dimensional subspace of R^3, indicating it forms a plane through the origin. Finally, the confusion regarding how three vectors can form a basis for the null space in R^6 is acknowledged, emphasizing the need for further clarification on spanning subspaces.
Lord Anoobis
Hello there. I'm currently trying to come to terms with the aforementioned topics. As I am self studying, a full understanding of these concepts escapes me. There's something I'm not grasping here and I would like to discuss these to clear away the clouds.
As I understand it, a basis for some vector space ##R^n## can be taken to be any set of ##n## linearly independent vectors, in other words an alternate set of axes as opposed to the usual ##(1,0,...,n),(0,1,0,...,n)## , etc. Correct?
So, in a sense it can be thought of as analogous to a Galilean transformation for relative motion?
Heading to work, will continue later or tomorrow.
Your notion of basis is correct.
Galilean transformation?
Yes, the transformation between the coordinates of two different frames of reference. Something that shows up in Newtonian mechanics.
What I'm not too clear on is basis when it comes to matrices. Take the following 3 x 2 matrix as an example.
##A = \begin{bmatrix} 1 & 3 \\ 1 & 1 \\ 3 & 1 \end{bmatrix}##
Keeping in mind what was stated before, am I correct that:
a) A basis for ##A## is a set of 3 x 2 matrices which are not row equivalent
b) A basis for the row space of ##A## is a set 2 of linearly independent row vectors which is ##{[1, 1], [0, 1]}##
c) A basis for the column space of ##A## is the two column vectors since neither is a scalar multiple of the other?
Concerning point (c), does this mean that the column space of ##A## is a plane through the origin since it must be a subspace of ##R^3##?
A better way to say it is a set of 3 x 2 matrices that are linearly independent.
It doesn't have to be those two vectors. Any two linearly independent vectors in ##\mathbb{R}^2## will do.
Those two vectors (the column vectors in the matrix above) are linearly independent, and so would work as a basis for the column space of that matrix. It wouldn't have to be those two, though. Any two vectors that lie in the same plane, and that are linearly independent (point in different directions in this case) would also form a basis for the column space.
Yes. The column space is a two-dimensional subspace of ##\mathbb{R}^3##.
Excellent, that clears up that misunderstanding.
##A = \begin{bmatrix} 1 & 3 & -2 & 0 & 2 & 0 \\ 2 & 6 & -5 & -2 & 4 & -3 \\ 0 & 0 & 5 & 10 & 0 & 15 \\ 2& 6 & 0 & 8 & 4 & 18 \end{bmatrix}##
The matrix A above is example 4 from Anton & Rorres in the chapter on row, column and null spaces. the solution shows the three vectors
##v_1 = \begin{bmatrix} -3\\1\\0\\0\\0\\0 \end{bmatrix}, v_2 = \begin{bmatrix} -4\\0\\-2\\1\\0\\0 \end{bmatrix}, v_3 = \begin{bmatrix} -2\\0\\0\\0\\1\\0 \end{bmatrix}##
forming the basis of the null space of A. What I Don't understand here is how do three vectors form the basis of a space in ##R^6##. How do three vectors end up spanning the subspace?
