Where Can I Find the Right Specs for a Battery Pack for Laser Tag Vests?
The discussion focuses on building a custom battery pack for laser tag vests using six NiMH 3800mAh 1.2V Panasonic 370A batteries wired in a block series. Participants identify a component on the lead, speculated to be a thermistor for temperature monitoring during charging, rather than a resistor. The conversation emphasizes the importance of safe charging practices, recommending a trickle charge at 10% of the battery capacity over quick charging methods. Additionally, users suggest sourcing components from electronic supply stores like Radio Shack for compatible parts.
  • Understanding of NiMH battery specifications and configurations
  • Knowledge of thermistors and their applications in battery management
  • Familiarity with safe charging practices for rechargeable batteries
  • Basic soldering skills for assembling battery packs
  • Research NiMH battery charging techniques and safety protocols
  • Learn how to measure thermistor resistance and temperature coefficients
  • Explore electronic supply stores for compatible battery components
  • Investigate intelligent chargers suitable for custom battery packs
Electronics hobbyists, battery pack builders, and professionals in the entertainment industry looking to create or maintain custom laser tag equipment.
ztekneq
I work at a local entertainment venue and wanted to experiment by building my own pack for current laser tag vests. The manuf charge us a FORTUNE!
So the specs are 6 NiMh 3800mah 1.2V 4/3 Panasonic 370a's wired in a block series
there is a small resistor (i think) on the lead but I cannot make out what its specs are..this is where i need some help. What do you guys think it might be?
It's unlikely to be a resistor that would just waste heat, it's more likely to be a fuse which is a good idea if you are strapping the batteries to your body.
k
quite possible... looked like it might have had bands like a resistor though...
its not on the lead to the connector so to say.. there is a wire (small) soldered to the first positive cap in the series drops down next to the battery and is then connected to the middle lead of the three lead series
http://www.tekneq-design.com/battery.jpg
In that case it's probably a thermistor to monitor temperature of the battery while charging.
A common way to charge NiCd/NiMH is to turn up the charging current until it starts to get hot and then back off a little.
If you aren't worrried about charging speed it is better/safer to just charge for 10-12 hours at 10% of the battery capacity.
is there any specifications that one would need to replace such a part?
You would need to know it's cold resistance which you can measure with a meter, you could estimate the temperature coefficient by putting in warm water and then measuring it's resistance again.
But like I said, it's easier/safer to just trickle charge the batteries, quick charging home made battery packs is a bit dangerous to the battery and you!
It is exactly a thermistor! I am actually duplicating an existing pack. What would be the downfalls of hooking in the wrong thermistor? I have an existing intelligent charger that is being used as well. Is there anyway to estimate what thermistor should be used?
You might want to try some electonic supply houses.
For instance, Radio Shack sell a 6 cell nicad pack for RC cars with charger for about $20.
They also sell connector adaptors.
10K
