Behavior of e^(i*x) at Infinity and Negative Infinity
  • Thread starter Thread starter Typhon4ever
    Infinity Limit
10 replies · 4K views · last reply
Typhon4ever
delta dirac function(x) * e^(-i*x) at ∞ and -∞
delta dirac(x)*e^(i*x)
I'm wondering how e^(i*x) looks like at infinity/-infinity. I know it has some sort of oscillating property i.e e^(pi*i)=e^(3pi*i). The problem is I'm trying to find the delta dirac function * e^(-i*x) at infinity and negative infinity but I don't know how to evaluate the exponential. I know the delta function should be 0 in both cases but I don't know if the exponential will turn out to be indeterminate or something else. I should get 0 from the whole equation.
How are you defining the Dirac delta? What does that imply about the product?
I'm not sure what you mean by how I'm defining the dirac delta.
Well, what does the Dirac delta evaluate to at any nonzero ##x\in\mathbb{R}##?
I'm assuming your "*" means multiplication, correct?
Yes "*" means multiplication. Anywhere except the origin is 0.
Typhon4ever said:
Ok. Using Euler's if I'm not mistaken just tells me the limit doesn't exist. What do I do then to evaluate this problem?
If you're referring to the limit ##\displaystyle \lim_{x \to \infty} e^{ix}##, then you're correct. That limit doesn't exist because ##e^{ix}## doesn't converge to a single value. But that's not the limit you were asking about. You should cogitate on the implication of your (correct) answer to Mandelbroth's question.
So I have the delta function at infinity which is 0 * a non converging exponential=...0?
Yes, that's the right answer, but you're not thinking about this correctly. Since you're interested in the limit as x goes to +∞, you can assume x>0. For any such value of x, ##\delta(x)e^{ix} = 0\times e^{ix} = 0##. Now you take the limit of this as x goes to +∞.
$$\lim_{x \to \infty} \delta(x)e^{ix} = \lim_{x \to \infty} 0 = 0.$$ The behavior of ##e^{ix}## doesn't matter.
