yuiop
- Messages
- 3,962
- Reaction score
- 20
According to the Wikpedia entry
"[URL
and this paper http://www.aapps.org/archive/bulletin/vol14/14_1/14_1_p03p07.pdf
the conclusion reached by Bell in his paradox is still disputed even by some scientists today.
Since the linked articles give plenty of mathematical explanations I thought a visual explanation of the paradox might help. (See attached diagram)
The left frame is the point of view of an inertial observer that remains in the initial reference frame of the green and yellow rockets that accelerate to simultaneously and with constant equal proper acceleration to a new constant velocity.
The centres of the green and yellow rockets are connected by a spring and slung under the green rocket is a rod supporting an unstressed spring that is connected only at one end to the green rocket. Comparison of the length contracted rockets and unstressed rod and and spring should give a visual indication of stress the connecting spring is under. If the spring was a fairly inflexible string, it is reasonable to assume it would snap if the final velocity is sufficient.
The blue rocket has constant velocity relative to the initial reference frame and is already going at the final velocity of the accelerating rockets. The right hand drawing is the rest frame of the blue rocket. In the blue rocket frame it can be seen that the yellow rocket takes off long before the green rocket. It can also be seen that in the blue rockets frame the green and yellow rockets are de-accelerating from a relative velocity to finally come to rest in the blue frame. In this case the with the chosen parameters the yellow rocket completes its de-acceleration phase and comes to rest just before the green rocket even takes off. It can also be seen that in the blue frame the green and yellow rockets appear to be undergoing "length expansion" rather than the normal length contraction. It is much easier to see in the blue frame why the connecting spring is stretched and why a connecting string would eventually snap.
Hope that the "visual explanation" helps :)
"[URL
