Bernoulli vs conservation of momentum (Reynolds transport theorem form)
The discussion revolves around the differences in results obtained from Bernoulli's principle and the conservation of momentum, particularly in the context of inviscid fluid flow. Participants explore a specific scenario involving fluid released from a faucet and another involving a falling elevator, questioning the conditions under which each approach yields different outcomes.
  • One participant notes a discrepancy between Bernoulli's equation and conservation of momentum, specifically regarding a factor of 2 in kinetic energy when analyzing fluid released from a faucet.
  • Another participant points out that the area of flow is not constant as the fluid falls, suggesting that this affects the application of conservation of momentum.
  • There is a discussion about whether conservation of momentum can yield correct results without accounting for area changes, with some suggesting that Bernoulli's principle may be safer in certain inviscid flow scenarios.
  • One participant mentions that conservation of momentum can be supplemented with additional equations, such as conservation of mass, to correctly account for changes in area.
  • A participant raises a similar issue regarding a falling elevator, noting that Bernoulli and conservation of momentum yield different terminal velocities, attributing this to pressure distribution effects.
  • Another participant emphasizes that the assumptions made in applying conservation of momentum may not always be justified, but this does not violate the principle itself.
Participants express differing views on the applicability and reliability of Bernoulli's principle versus conservation of momentum in specific fluid dynamics scenarios. There is no consensus on whether one approach is definitively superior to the other, and the discussion remains unresolved regarding the conditions under which each method should be used.
Participants highlight limitations related to assumptions about constant area and pressure distribution, which may affect the validity of the results obtained from conservation of momentum. The discussion indicates that these assumptions need careful consideration in fluid dynamics problems.
Urmi Roy
So I've found several instances in which Bernoulli and Conservation of momentum (in Reynolds transport theorem form) give different answers for the study of an inviscid fluid.
Let's consider a simple situation as described in my diagram attached.
Basically a tap/faucet is releasing fluid, which is known to be inviscid. We want to find the velocity at the bottom just before it hits the ground.
My solution does it out with both Bernoulli and conservation of momentum, but the factor of 2 that comes from the kinetic energy in Bernoulli doesn't appear in the final expression from
This is only a simple example and I've come across this discrepancy about the '2' several times. I'm not sure what is going on here and any help would be much appreciated!
The area is not constant and the flow becomes narrower as it falls as an effect of the flow speeding up. Your second expression also has the wrong sign.
Sorry about the sign problem, that's just careless of me. So apart from that, conservation of momentum doesn't give the right answer because it can't account for the area change? Does that mean that if there is an inviscid flow, it's just safer to use Bernoulli?
As before, my question is that what causes the difference between these two approaches?
There is nothing wrong with using momentum conservation, but you have to supplement is with additional equations describing how the fluid evolves, e.g., conservation of mass. If you do it correctly, the area as a function of the height will drop out of the equations. The only thing that went wrong was that you assumed constant area (which is an assumption that broke mass conservation).
In fact, you can derive the Bernoulli equation from momentum conservation and some additional requirements.
Oh okay, I get your point. Thanks! Just to confirm with you, I had another problem where an elevator is falling through air and the Reynolds number is found to be much larger than 1,so that the flow is approximately inviscid. Again, Bernoulli and Conservation of momentum give different answers for the terminal velocity. I'm thinking this is because at the bottom surface of the elevator there is a pressure distribution while conservation of momentum assumes an average pressure all along the surface. I can show you my working for this if you prefer.
But from your response I get that if for an inviscid flow the two approaches don't give the same answer, there's probably a mistake somewhere- they should always be equivalent.
Thanks!
This is again an assumption that you might make in momentum conservation, but your assumption may or may not be justified. The momentum conservation in itself is not violated.
Thanks for all your help, Orodruin!
  • · Replies 18 ·
10K
10K
