gen x
- 181
- 11
- Homework Statement
- testing Bernoulli in real life experiment
- Relevant Equations
- P1+1/2 ρ V1^2 = P2 + 1/2 ρ V2^2
A1 V1= A2 V2
If have close pipe system with water inside pressurized at P1= 200 000Pa absolute, density 1000kg/m3, wider pipe diameter=2cm, contraction pipe diameter=1.49cm, that is contraction area ratio A1/A2=1.8
a) If water is stationary(pump OFF) and if I drill a hole anywhere at pipe, water will leak out, because pressure(200kPa) inside is higher than atmospheric pressure (101 325Pa).
b)If I turn on pump and water start flowing with with v1=10m/s in A1 wider section, from Bernoulli equation I will get pressure P2 in contraction(section A2) 88 491Pa, that mean, if I now drill hole in narrow section, water will not leak out, air will be sucked in because P2 is lower then atmospheric pressure.
How realistic is this?
