Bernoulli's equation and a water tank
The discussion centers on applying Bernoulli's equation to a water tank problem involving a hole at height y. Participants derived the flow speed v of water exiting the hole as v = sqrt(2g(h-y)), where g is the acceleration due to gravity. They also explored the maximum range x_max of the water stream, concluding that y = 1/2 h yields the maximum range. The final expression for maximum range was discussed as x_max = 2sqrt(y(h-y)).
  • Understanding of Bernoulli's equation and fluid dynamics
  • Knowledge of kinematic equations for projectile motion
  • Familiarity with algebraic manipulation and substitution
  • Basic concepts of gravitational acceleration (g)
  • Study the derivation of Bernoulli's equation in fluid mechanics
  • Learn about projectile motion and its equations
  • Explore optimization techniques for algebraic expressions
  • Investigate real-world applications of fluid dynamics in engineering
Students studying physics, particularly those focusing on fluid dynamics and kinematics, as well as educators seeking to enhance their teaching of these concepts.
notagenius08
A water tank of height h has a small hole at height y. The water is replenished to keep h from changing. The water squirting from the hole has range x. The range approaches zero as y goes to 0 because the water squirts right onto the table. The range also approaches zero as y goes to h because the horizontal velocity becomes zero. Thus there must be some height y between 0 and h for which the range is a maximum.
a)Find an algebraic expression for the flow speed v with which the water exits the hole at height y.
b)Find an algebraic expression for the range of a particle shot horizontally from height y with speed v.
c)Combine your expressions from parts A and B. Find the maximum range x_max
d)Find the height y of the hole.
v1A1=v2A2
p1+.5(density)v1^2+(density)gy1=p2+.5(density)v2^2+(density)gy2
deltaK+deltaU=Wext
a)Solving for v2(assuming this is outside the can velocity):
v=sqrt of 2p1/denisty-2p2/density+v1^2+2gy1-2gy2
computer told me to check my answer, so I guess its wrong.
b)distance=rate*time
t=sqrt of 2h/g
x=v*t
haven't tried part c or d cause I can't get part a) right.
Thanks for any help.
Ok, so I have messed around a bunch and I think the answer for part a) is:
v=sqrt of 2*g(h-y)
Can anyone tell me if I am on the right track?
that's what i got for v, what did u get for the max range of x??
I typed in your equation for v and its correct. For my services, you think you could explain a bit how you got it?
Oh just realized that was posted some time, probably doesn't need my services, but . . .
Bluebear, I'm stuck at xmax = sqrt(4y(h-y)) I literally just substituted the answer from A into B.
But I think we have to get rid of y somehow so I'm hesitant to submit this. Have you gotten it yet?
the velociyty for an obj falling in kinematics is sqrt[2gh]
Vf^2 - Vi^2 = 2as where a = acceleration and s = displacement
here a = g since its falling and s = h-y = distance the water has fallen up to the point of the hole.
and Vi = 0
so Vf^2 = 2*g*(h-y)
and solve for v by taking the square root of both sides
and no I haven't tried c yet but it is part of my homework so I will try very soon
hope this helps
the eqn you got i think only solves for x, but not Xmax
y = 1/2 h for max range, i think you can solve for the rest
you had the right idea with sqrt(4y(h-y)) take the 4 out and u get 2sqrt(y(h-y))
looking at inside the radical y(h-y). you want that value to be the largest as possible. But when you increase y, u decrease h-y and vice versa, so the biggest value u can get is 1/2 * 1/2. its a little common sense twist
Great, thanks for your help. You haven't by any chance also been assigned 15.58, the boat problem? There's a thread called "buoyancy force on a steel boat", where I describe my work on it.
  • · Replies 29 ·
