Best Derivation of E=mc^2 - Fdx = V^2 dm
  • Context: Undergrad
  • Thread starter Thread starter JLT
    Derivation
The discussion centers on the derivation of Einstein's equation E=mc², with participants exploring various approaches and interpretations. Key points include the use of relativistic momentum (p = γ(u) m u) and the relationship between force and energy through the integral of work done (W_tot). The conversation highlights that E=mc² is a special case of a broader framework in special relativity, emphasizing the importance of understanding Einstein's postulates and the four-momentum concept. Participants suggest that the best derivation involves minimal assumptions and logical progression from these foundational principles.
  • Understanding of special relativity principles and Einstein's postulates
  • Familiarity with relativistic momentum and the Lorentz factor (γ)
  • Basic knowledge of calculus, particularly integration and differentiation
  • Concept of four-vectors in physics
  • Study the derivation of four-momentum and its implications in relativistic physics
  • Learn about the integral of work done in the context of relativistic mechanics
  • Explore the relationship between energy, mass, and velocity in special relativity
  • Investigate resources on special relativity, such as David Morin's book on the subject
Students and educators in physics, particularly those focusing on special relativity, as well as researchers interested in the foundational aspects of energy-mass equivalence and relativistic mechanics.
JLT
TL;DR
best derivation
F= V dm/dt = V (dm/dx)(dx/dt) = V^2 (dm/dx)
Fdx = V^2 dm
E = m v^2. ,mass flowing with constant velocity
If velocity is changing rather than mass, then E = 1/2 m V^2
Ok, joking aside, what is the best derivation of E= mc^2 ?
  • Skeptical
What does "best" mean?
(one dimensional case) start with relativistic momentum ##p = \gamma(u) m u##
Force: ##F_\text{res} = \dfrac{\mathrm{d} p}{\mathrm{d} t} = \dfrac{\mathrm{d} }{\mathrm{d} t} (m\gamma(u) u) = ma\gamma(u)^3## where ##a## is the acceleration.
##\displaystyle \int a \gamma(u)^3 \mathrm{d} x = c^2\gamma(u) + C##
Work: ##\displaystyle W_\text{tot} = \int_{x_1}^{x_2} F_\text{res} \mathrm{d} x = m\int_{x_1}^{x_2} a \gamma^3 \mathrm{d} x = mc^2\cdot \gamma (u(x_2)) -mc^2\cdot \gamma(u(x_1)) =mc^2\cdot \gamma (u_2) -mc^2\cdot \gamma(u_1) ##
Work is defined as change in kinetic energy, and kinetic energy ##E_\text{k}## at a given instant is defined as the work needed to bring particle to a certain speed ##u_2## from rest ##u_1=0##.
Thus, we have ##E_\text{k} = m\gamma(u) c^2 - mc^2##.
The last term ##mc^2## can be interpreted as "rest energy" and therefore the ##m\gamma(u) c^2 ## as the total energy ##E_\text{tot}##
Work: ##\displaystyle W_\text{tot} = \int_{x_1}^{x_2} F_\text{res} \mathrm{d} x = m\int_{x_1}^{x_2} a \gamma^3 \mathrm{d} x = mc^2\cdot \gamma (u(x_2)) -mc^2\cdot \gamma(u(x_1)) ##
Darn, I'm on my phone, cannot see posted equations.
Best? Occam's razor kind of best.
E = mc^2 is also not even the full story. It is a special case of something having zero speed as measured in a certain frame of reference.
No aether, what was it- splitting light and bouncing back no matter how the thing is rotated with respect to the rotating earth that is flying around the sun.
I'm on vacation, just looking for book suggestions.
There are plenty of threads where people are asking for book recommendations regarding learning special relativity.
I can suggest the book by Morin https://scholar.harvard.edu/david-morin/special-relativity
JLT said:
TL;DR Summary: best derivation
IMO, the best derivation is to derive the four-momentum and then define its norm to be mass.
Is there any relationship between:
E = m v^2
and E = Pressure*Volume?
PV = (density *Volume) * velocity^2
Pressure=density*velocity^2
almost starts looking like Bernoilli's equation.
  • Skeptical
E = m v^2
The first one is wrong and the second one is right. Not sure if that is the sort of relationship you are referring to.
It looks like you are just throwing letters and equal signs randomly on a wall.
Sorry, on my phone without equation editor. Instead of E=m c^2, could be E=mv^2 where v is any constant velocity of any fluid. See original post, a chain rule, its a mass flow rate equation.
E = m v^2
Of course, for dimensional reasons, one can see resemblances to possibly familiar equations.
While these may hint at connections from relativistic objects,
the appropriate path is to study the relativistic versions of those familiar equations:
e.g.
https://www.google.com/search?q=relativistic+kinetic+theory
https://www.google.com/search?q=relativistic+fluids
https://www.google.com/search?q=relativistic+statistical+mechanics
...but this is moving away from the original question.
None of this has anything to do with ##E = m c ^2##.
By that you mean the derivation that requires the fewest starting assumptions?
Most derivations start with two straightforwardly stated and universally applicable assumptions, namely Einstein’s postulates. From there it's just logic and a lot of high school math.
However it is a lot of that high school math. @malawi_glenn's post #2 in this thread follows the same path that Einstein and his contemporaries took to get to ##E=mc^2## from the postulates, but there's a fair amount of preliminary work required to get to where we can set up the integral. In #7 @Dale uses the norm of the four-vector, an approach that is much more aligned with modern thinking, but again there's a lot of preliminary work required to get to that four-vector formulation. I was tempted to post my "simplest" derivation: Set ##p=0## in the general relationship between mass, energy, and speed/momentum:$$E^2=(m_0c^2)^2+(pc)^2$$but of course that just invites the question, where did that relationship come from? And the answer is the same as for the other two: Start with Einstein's postulates and do a lot of high school math.
There's no way of getting to ##E=mc^2## without understanding all of special relativity, the same way that I can't fill the house with the delicious smell of a baking cake without actually baking a cake. That makes MalawiGlen's second answer, the one in #6, perhaps the most useful one.
You can borrow my wife :oldbiggrin: (or at least her perfume)
  • Haha
...but can she derive ##E=mc^2##?
She can memorize it for sure, but she can not understand a single step :sorry:
But her perfume, I promise every day I get back from work I swear I think she has made newly baked cinnemon buns 🥐
What do you mean by derive the four-momentum?
I mean construct it and show that it is a four-vector.
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 55 ·
  • · Replies 36 ·
