Best way to non-conductive coat aluminum?
  • Thread starter Thread starter kolleamm
    Aluminum
The discussion revolves around methods to coat aluminum pieces to render them non-conductive for a specific project. Participants explore various coating techniques, including anodization, powder coating, and PVC dip coating, while considering factors such as durability and application requirements.
  • Some participants suggest using anodization as a method to make aluminum non-conductive, noting its effectiveness up to 1000 V.
  • Others propose powder coating with epoxy as a way to achieve a true insulator, highlighting its durability compared to other coatings.
  • Dip coating with PVC is mentioned as another viable option, with some participants noting its ease of application and potential for higher voltage breakdown compared to powder coating.
  • Concerns are raised about the thinness of anodization, which may be susceptible to damage from scratches or pressure, leading to potential conductivity.
  • Participants emphasize that the best coating method depends on specific application requirements, including durability, UV exposure, and voltage levels.
  • One participant expresses reluctance to share detailed information or images of their project, which leads to a suggestion that more context would aid in providing better advice.
There is no consensus on the best method for coating aluminum to make it non-conductive, as multiple competing views and techniques are presented, each with its own advantages and considerations.
Participants mention various factors that influence the choice of coating, such as voltage breakdown, material thickness, and environmental exposure, but do not resolve these considerations.
kolleamm
I have some aluminum pieces for a project that need to fit into some slots, they are about the size of your hand. What would be the best way to coat them so they are no longer conductive? Something thin like an enamel I was thinking but perhaps someone here has a better idea.
Thanks in advance!
Thanks in advance!
explain your setup more fully and why they need to be non-conductive. Maybe a drawing/photo or 2
This may help with the other ideas :smile:Dave
How about anodisation?
To make it REALLY non-conductive, a true insulator you can powder coat with epoxy. Another option is dip coat with PVC.
There are many options - what is best depends on the application requirments. Durability, UV (sun ) exposure, voltage to be applied. etc...
I would really like to post a picture of the piece and the design however that could potentially give away my idea.
Then you will have to do some/most of your research yourself. However, voltage breakdown is usually dependent upon thickness and the actual material. I suspect PVC coating to have a higher voltage breakdown than powder coating. Anodizing would work for very low voltage levels except it is such a thin coat, that any scratch or pressure could potentially damage the thin shell and allow current to flow ie voltage breakdown. And if you have an AC voltage, you may actually develop capacitive reactance.
Here is your best answer:
But depending on those parameters, stuff like this makes an inexpensive solution. There are many similar brands; I don't endorse any particular one
http://www.homedepot.com/catalog/productImages/1000/c3/c33bbcfa-a252-4799-973c-3746f2dee11f_1000.jpg
Anodising can be isolating till 1000 V and is way harder than any plastic coating.
Those sort of responses really don't go well on any forum
If you don't want to give details, then you cannot expect forum members wasting their time playing the guessing game
There is electrical grade epoxy powder coat - EXAMPLE, PVC is pretty good, but softer, and likely to get damaged. Still there are like 6 key factors in making the "best way".
In reading this again - the Aluminum parts can be dip coated with PVC very easy, but they have to be heated. I know a company (where I used to work) that does this with electrical grade PVC.
  • · Replies 16 ·
