Billiards Ball Collision Analysis
2 replies · 6K views · last reply
JonathanSnow
2 identical biliards balls collde after a glancing collision determine the speed of the other ball,
MaVa + MbVb = MaVa' + MbVb' ?
is this just as simple as the momentum formula before and after, or am I forgetting somthing obvious, because 5cm/s in the other direction dosent make any sense
also is there a different formula to use for this when its on an angle, i know momentum before has to equal momentum after as does kinetic energy, mind you its not asking for kinetic, only speed, the balls are the same size so in the momentum formula we can get rid of the mass?, and its obvious its perfectly elastic anyways.
If the collision isn't on a straight line you can use the same momentum equation, only now the velocity and momentum are vectors with 2 components.
