Binary to Gray Conversion Program
  • Thread starter Thread starter uknowwho
6 replies · 2K views
uknowwho
We just started out C++ and I thought of making a conversion program from binary to gray and vice versa just for fun and to improve my skills
I was successful to make conversions of 4 bits
#include <iostream>
using namespace std;
int main() {
int Choice;
bool g0,g1,g2,g3,b0,b1,b2,b3;
count<<"For Binary To Gray Code Enter 1." << endl <<"For Gray Code to Binary Enter 2." << endl;;
cin>>Choice;
if(Choice==1){
count<<"Enter the Binary Bits." << endl;
cin>>b0>>b1>>b2>>b3;
count<<"Orginal Binary Form: "<<b3 <<b2 <<b1 <<b0 << endl;
g3=b3;
g2=b3^b2;
g1=b2^b1;
g0=b1^b0;
count<<"Converted Gray Code Form: "<<g3 <<g2 <<g1 <<g0 << endl;
else if(Choice==2){
count<<"Enter The Gray Code Bits." << endl;
count<<"g0: ";
cin>>g0;
count<<"g1: ";
cin>>g1;
count<<"g2: ";
cin>>g2;
count<<"g3: ";
cin>>g3;
count<<"Orignal Gray Code Form: "<<g3 <<g2 <<g1 <<g0 << endl;
b3=g3;
b2=b3^g2;
b1=b2^g1;
b0=b1^g0;
count<<"Converted Binary Form: "<<b3 <<b2 <<b1 <<b0 << endl;
return 0;
but what if I want to store the number of bits entered by the user in real time is it possible?
I heard using vectors is more useful in c++ than arrays? Also how to store the bits in a string so that the user can enter the bits in one line without spaces.
We haven't studied loops and making functions as of yet so it would be great If you suggest simpler ideas
Without loops and functions, you are limited to a fixed number of input bits (or an insane amount of if-statements), I think. You can use a string, but I don't see a reasonable method to tell C++ "do this [stringlength] times" without loops or functions.
In the same way you can store a single bit in a bool.
Code:
#include <string>
#include <iostream>
int main ()
    string binarybits;
    cout << "Enter the binary bits (without spaces): ";
    cin >> binarybits;
    cout << "OK, you entered " << binarybits << "." << endl;
    return 0;
Ok if we were to use loops what the simplist way to do it without getting to complicated
i know the basics of loops
This
is a valid requirement, but this
is based on an invalid assuption - you don't need a string for buffering the input when whitespaces are absent, pls consider this:
Code:
#include <iostream>
#include <string>
#include <vector>
#include <cctype>    // iswspace
#include <stdexcept> // logic_error
#include <iterator>  // ostream_iterator
#include <algorithm> // std::copyint main(/*int argc, char* argv[]*/) {
    typedef std::vector<bool> bit_vec;
    typedef std::ostream_iterator<bit_vec::value_type, char> outp_it;
    bit_vec bv;
    char c;
    try {
        while (std::cin.get(c)) {
            if ((c == '0') || (c == '1')) {
                bv.push_back(bool(c - '0'));
            } else if (!iswspace(c)) {
                throw std::domain_error(std::string(&c,1).c_str());
    } catch (std::domain_error& e) {
        std::cerr << "Invalid literal: " << e.what() << std::endl;
        exit(1);
    std::copy(bv.begin(), bv.end(), outp_it(std::cout));
    std::cout << std::endl;
    return 0;
You better downsize that yourself, from this
I cannot get what you're allowed to use - apparent free choice of containers but no loops or functions yet does not appear consistent.
Regards, Solkar
Solkar said:
This
Code:
#include <iostream>
#include <string>
#include <vector>
    bit_vec bv;
    char c;
    try {
        std::cerr << "Invalid literal: " << c << std::endl;
        exit(1);
    return 0;
Regards, Solkar
No we haven'e learned neither of those as of yet(vecors and arrays).I googled for those.
Solkar said:
Code:
Nonsens, that's meant to be interactive, isn't it?
So scratch that and put
Code:
 while (std::cin.get(c) && c != '\n')
