Biological Effects of Radiation - 1st Year UG Physics
The discussion revolves around the biological effects of radiation, specifically focusing on Polonium-210, its decay process, and the associated calculations regarding its activity and potential hazards. The subject area includes nuclear physics and radiation biology.
  • Mixed
  • Participants explore various calculations related to the decay of Polonium-210, including energy release, activity, and biological dose. There are attempts to clarify the correct exponent in activity calculations and the total energy emitted by alpha particles. Some participants question the necessity of detailed calculations for assessing the hazard of historical samples.
The discussion includes attempts at calculations and some guidance on interpreting the results. Participants have raised questions about assumptions and the relevance of certain calculations, indicating a productive exploration of the topic without reaching explicit consensus on all points.
Participants mention assumptions regarding the biological effectiveness of radiation and the relevance of half-life in determining the hazard of Polonium-210 over time. There is a focus on the implications of decay and the fraction of remaining atoms in historical contexts.
P91
Questions
Polonium-210 has a half life of 138.4 days. It decays to stable Pb-206 by emitting an alpha particle with a kinetic energy of 5.31 MeV. Alpha radiation of this energy has a relative biological effectiveness of 20.
a) If the difference in mass of Po-210 and Pb-206 nuclei is 4.00731u and the mass of an alpha particle is 4.00151u, estimate the fraction of the energy released in the radioactive decay of a Po-210 atom that is converted into kinetic energy of the alpha particle. What happens to the rest of the energy?
b) How many atoms are there in 1 microgram of Po-210?
c) Calculate the activity in becquerels of 1 microgram of Po-210
d) What is the total energy in joules of all of the alpha particles emitted by 1 microgram of Po-210 in one second?
e) If 1 microgram of Po-210 were ingested by a 70kg man, calculate the total equivalent radioactive dose in sieverts that he would receive in 48 hours. Comment on any assumptions that you make in your calculation.
f) Do you think that a sample of 1 gram of Po-210 isolated by Marie Curie in 1929 would still be a significant hazard today? Explain your reasoning
Dose equivalent in Sv = Absorbed dose in Gy x RBE
1u = 1.6605e-27 kg
Initial activity/initial number of atoms = time constant
half life = time constant * natural log(2)
half life = natural log (2) / decay rate
Number of atoms = Initial number of atoms * e^-(time of decay)*(decay rate)
dN/dt = - decay rate * number of atoms
Activity = decay rate * number of atoms
Attempt at a solution
a) I said that the initial energy of Po-210 is equal to the energy of Pb-206 + energy of alpha particle + kinetic energy. I rearranged to get Kinetic Energy(alpha) = change in mass * c^2 which gave my answer as 6e-10 Joules.
b) using the number of particles in a mole I divided the mass by the molar mass and multiplied by the number of particles. My answer was 2.86e15 atoms
c) using the equation below
I plugged in my value of half life and found the decay rate and put that into the next equation.
My answer was 1.66e9 Bq
d) Because the time period is one second, I divided the activity by the number of atoms in a mole of a substance. I then multiplied this by the molar mass of helium and my result was 1.11e-14 grams.
e) I have calculated the number of atoms emitted by using the initial amount and subtracting the amount at t = 48 hours. I now have a number for emitted particles in the man of 2.73e14 which has an energy of 1.638e5 Joules assuming that the particles have zero kinetic energy. I do not know how to convert this into the 'dose' that he would receive. I don't understand the relative biological effectiveness fully.
f) My initial thoughts are that I should calculate the number of atoms left from 1 gram, or the activity. If this is very small, which it must be since the half life is only 138.4 days - then it will not be a hazard today.
Hi,
I think youve misstyped the exponent for the activity..i got 1.66*10^8
Also part d) asks for the total energy of the emiited alpha particles, the energy of one alpha is given in the question as 5.31MeV. so it think this energy needs to multiplied by the number of alspha particles emitted in one second
I don't think you need to do any calculations here. Just remember the definition of the half-life and the amount of time that's passed, then get the fraction of the original atoms that remain (you don't even need to do a precise calculation, just a Fermi estimate would be more than enough to show that it's harmless). The question says "explain your reasoning" not "do pointless calculations", after all.
misunderstood said:
Hi,
Thanks guys. I now have these as my answers:
a) 6e-10 J
b) 2.86e15 J
c) 1.66e8 Bq
d) 1.41e-4 J
e) 695 Sv
f) non-mathematical explanation
If anyone has worked them out, do your answers agree?
  • · Replies 23 ·
10K
