What is the Correct Q for Calculating Black Hole Temperature?
The discussion centers on calculating the temperature of a black hole using its entropy, derived from the relationship between energy and particle count. The participant approximates the entropy as S = (2 M R c k_b)/h, where R is the Schwarzschild radius (R = 2GM/c^2). The confusion arises in determining the correct value for Q in the equation S = Q/T, with the literature suggesting Q = (1/2)Mc^2, contrasting with the participant's initial assumption of Q = Mc^2. The discrepancy in temperature calculations stems from the nature of energy escaping the black hole, specifically the particle pairs created at the event horizon.
  • Understanding of black hole thermodynamics
  • Familiarity with the Schwarzschild radius and its implications
  • Knowledge of entropy in statistical mechanics
  • Basic principles of quantum mechanics related to particle creation
  • Research the derivation of black hole entropy using the Bekenstein-Hawking formula
  • Study the implications of Hawking radiation on black hole thermodynamics
  • Explore the role of particle pairs at the event horizon in black hole physics
  • Investigate the differences between classical and quantum descriptions of black hole temperature
The discussion is beneficial for physicists, astrophysicists, and students studying black hole thermodynamics and quantum mechanics, particularly those interested in the relationship between entropy and temperature in black holes.
linda300
hey guys,
i'm working on this question to approximate the entropy of a black hole,
the approximation is that for the maximum entropy to be obtained you need a maximum number of particles to create the black hole, the particles must have low energies - large wavelength photons, but the maximum wavelength of the photons are twice the radius of the black hole.
so E = hc/λ=hc/2R
R = 2GM/c^2 (black hole of mass M)
The total energy of the black hole will be E_t = M c^2 and need
E_t = N hc/2R =M c^2
so from here you can find N to be N= 2MRc/h
and using the approximation that S = N k_b you can find the entropy of the black hole
S = (2 M R c k_b)/h
this entropy differs from the literature entropy by a factor of pi which i assume is due to the nature of the approximations,
my problem is, i want to find the temperature of the black hole using the entropy S i calculated
S = Q/T, but what is Q?
I have found online that Q=Mc^2, but I don't understand why.
using the literature expression for S i tried to derive the literature expression of the temperature by T = Q/S using Q=Mc^2 but the result differs by a factor of 2.
here is the working (literature case)
S=k_b (4 pi G M^2)/(hbar c)
T= Q/S = Mc^2 (hbar c)/ (4 pi G M^2 k_b)
=c^3 hbar/ (4 pi G M k_b)
but the literature value of T is
c^3 hbar/ (8 pi G M k_b)
which means that Q should = (1/2)Mc^2, but i don't understand why
what is the correct Q i should be using?
thank you in advance
No one has any ideas?
I'll be honest and tell you I don't really know, but what I think based on something I read once is that the energy (temperature) that escapes from a black hole (the only temperature you could measure) are the particle pairs that are created at the event horizon. It is 1/2 because only one of the pair escapes and gets far enough away to decay relasing the energy (e=mc^2) ? That really is a wild guess.
