Black hole singularity, a time-like surface?
19 replies · 3K views · last reply
Hill
TL;DR
In "General Relativity: The Theoretical Minimum" (Susskind, Leonard; Cabannes, André), the surface corresponding to the black hole singularity is described as time-like. Why?
Below is the description from the book. I thought that hyperbolas in the right quadrant are time-like and hyperbolas in the upper quadrant are space-like. If it were so, the surface ##r=0## would be space-like, but the book says otherwise. -- ?
Minkowski diagram with axes T (vertical) and X (horizontal) and origin O, grey diagonal light lines, and labelled r = 0 on an upper hyperbola; several right-hand hyperbolas are also drawn.
You are correct. The singularity in a Schwarzschild black hole, which is what the diagram is showing, is spacelike. That is a huge error, which I am extremely surprised to see in that book.
I guess Susskind needs to read Wald, section 6.4, which explicitly states what I state in the quote above.
On a Kruskal diagram, like on a Minkowski diagram, null lines slope at 45° and timelike lines are steeper than that.
The body text correctly notes that the singularity is more like a time than a place, though, meaning it is spacelike (any "now" must be a spacelike surface - or line in the case of the Schwarzschild singularity). So the caption is a typo that's got past the authors and editors.
At least two of them, since "time-like" appears in both the Figure label and the paragraph of text beneath it.
In other words, the hypersurfaces ##r=\text{const}## with ##r<r_{\text{S}}## are spacelike since the corresponding ##r##-lines are "normal vectors" of this hypersurface are time-like. It's often confusing, but one has to remember that a hypersurface is spacelike if the normalvector is timelike and vice versa. So I'd also say the singularity ##r=0## is a spacelike hypersurface rather than calling it time-like.
May be they meant to say that it is like a moment of time. Many places at the same time.
But that's indeed a spacelike hypersurface ;-)), but I'm not too harsh with textbook authors concerning typos. Tell me a recipy how to produce typo-free textbooks ;-)).
I'd call it "misspoken" rather than "typo". It doesn't matter really. I'm just glad that I've spotted it and that my understanding so far is correct.
The text sort of says that, but the correct term for such a surface is "spacelike"--it's a surface that can be viewed as "space"--many places--at an instant of time.
Hmm... The book insists: 20 pages later, referring to this figure,
Spacetime diagram with horizontal X axis and vertical T axis, showing hyperbolic curves of constant rho labelled rho = 1, 2, 3 in the right quadrant, and constant omega rays labelled omega = 0 to 3; upper quadrant shows hyperbolas for r = 0 and r = 1/2 with rho squared less than 0, and grey diagonal lines marking horizon H.
it says,
Printed text reading: 2. In the same upper quadrant, the straight lines coming out of H are still lines of constant t, or equivalently constant ω. But they are now space-like. And the hyperbola of a given r is time-like.
If by "upper quadrant" they mean the black hole region, this is of course wrong. The constant ##t## lines in the black hole region are timelike, and the constant ##r## hyperbolas are spacelike.
I am skeptical that these were typos. Based on my previous experience reading papers by Susskind, I suspect he is making up his own terminology (where "space-like" means "like a point in space" and "time-like" means "like an instant of time") and either hasn't bothered to check the literature, or doesn't think it matters. Which, given that this book is supposed to be for pedagogy, does not strike me as a sound strategy. I hope I'm wrong.
They do.
PeterDonis said:
his own terminology
Not in this case: earlier in the book he says,
Printed text: There are three possibilities: (Δτ)² can be positive, in which case the separation between the two points is said to be time-like; it can be negative, in which case the separation is space-like; or it can be zero, in which case the separation is light-like.
Some terrible search-and-replace disaster?
##t## is a spacelike coordinate inside the horizon which means that lines of constant ##t## (on this 1+1d diagram) are time-like, and vice-versa outside.
That's an amazing mistake in a (pre-)introductory textbook then. It's anyway confusing with space-like vs. time-like concerning 3D hypersurfaces (already in SR but the more in GR).
The right local criterion is that a hypersurface is called space-like if the normal vectors are time-like.
In the usual Schwarzschild coordinates for ##r<r_{\text{S}}## the ##t##-coordinate is space-like and the ##r##-coordinate is time-like (which adds to the confusion, because it's labelled ##t## for "time" and ##r## for "radial coordiante" due to the fact that ##t## is the time-like coordinate and ##r## a space-like coordinate outside the event horizon, i.e., for ##r>r_{\text{S}}##).
Now for the hypersurfaces defined by ##t=\text{const}## the lines ##(r,\vartheta,\varphi)=\text{const}##, i.e., the ##t##-lines are spacelike for ##r<r_{\text{S}}##, and they are the "hypersurface normal vectors", and thus these hypersurfaces are time-like.
Y'know, the more I think about it the more plausible this hypothesis becomes.
In itself that quote could be consistent with standard terminology, since the signs of squared intervals depend on what metric signature convention you adopt. In standard terminology, the quote you give is simply describing the standard timelike signature convention.
But if all he's doing is using the standard timelike signature convention, then he's using it wrong in the other quotes you give. So he can't just be using standard terminology.
He uses the standard terminology everywhere else. Here are some examples:
Text reading: With this form for the metric tensor, we can check that equation (21b) expressing the proper time is the same equation as dτ² = dt² − dx² − dy² − dz²
Diagram of a light cone with apex at the origin, showing a time-like interval: an upward arrow labelled dX^μ points from the apex through the upper cone, labelled Figure 2: Time-like interval.
Spacetime light cone diagram with two cones meeting at a vertex, and an arrow labelled dX^μ leaving the vertex outside the cones, illustrating a space-like interval.
Interesting, so his usage is inconsistent. That would seem to be a point in favor of the "typo" theory.
