Bland's problem on modules generated by submodules
  • Topic:
  • Thread starter Thread starter Math Amateur
    Modules Set Sets
66 replies · 9K views · last reply
Math Amateur
MHB
I am reading Paul E. Bland's book "Rings and Their Modules" ...
Currently I am focused on Section 4.1 Generating and Cogenerating Classes ... ...
I need some help in order to make a meaningful start on Problem 2, Problem Set 4.1 ...
Problem 2, Problem Set 4.1 reads as follows:( *** NOTE ... due to some problem I cannot upload scans/images at the moment ... so until the problem is resolved MHB members will need to have access to Bland's book ... Oh! image appeared on my screen at end of post ... )Can someone please help me to make a meaningful start on Problem 2 ...
Peter
$\Rightarrow )$
Let $\phi:M^{(\Delta)} = \bigoplus_\Delta M_\alpha \to N$ be the “generating epimorphism”, $M_\alpha = M$.
$i_\alpha: M_\alpha = M \to \bigoplus_\Delta M_\alpha $ are the canonical inclusions for all $\alpha \in \Delta$.
Define $\phi_\alpha = \phi \circ i_\alpha$.
$f:N \to N’$ is given, $f \neq 0$.
1) make a diagram
2) prove that $f \circ \phi \neq 0$
What is your next step?
steenis said:
$\Rightarrow )$
1) make a diagram
Thanks Steenis ...
Late now in southern Tasmania (edge of the world 😌 Strong winds ... 115 km per hour roaring round my old house ... )
Will work on problem ... based on your advice ... tomorrow morning...
Thanks again ...
Peter
steenis said:
$\Rightarrow )$
1) make a diagram
Thanks for the advice ...!We are trying to show that
$$M \text{ generates } N \Longrightarrow$$ for each non-zero R-linear mapping $$f \ : \ N \rightarrow N'$$ there is an R-linear mapping $$h \ : \ M \rightarrow N$$ such that $$f \circ h \ne 0$$ ... ...
Now $$M$$ generates $$N \Longrightarrow \exists$$ an epimorphism $$\phi \ : \ M^{(\Delta)} = \bigoplus_\Delta M_\alpha \to N$$ ...
... and we define $$i_\alpha: M_\alpha = M \to \bigoplus_\Delta M_\alpha$$ ...
... and further define $$\phi_\alpha = \phi \circ i_\alpha$$ ...
and we are given $$f \ : \ N \rightarrow N'$$ ...A diagram of this is shown below:View attachment 8146
Now ... you asked me to show that $$f \circ \phi \ne 0$$ ...
That is ... it is not the case that $$f \circ \phi (x) = f( \phi (x) ) = 0$$ for all $$x \in \bigoplus_\Delta M_\alpha$$ ...
(best to find a particular x such that $$f \circ \phi (x) = y \ne 0$$ ... but how ...? maybe $$1$$ maps to $$1$$ ...?)
But $$\phi$$ is an epimorphism and so maps to all of $$N$$, and then $$f \ne 0$$ ... so we can conclude that $$f \circ \phi \ne 0$$ ... ... but ... ... is this a valid argument ... ? ... suspect not ..Then how do we progress from here ...
Can you help further ... ?
Peter
***NOTE***
... ... it seems to me that $$\phi$$ might be our required R-linear map such that $$f \circ h = f \circ \phi \ne 0$$ ... $$\phi$$ is indeed R-linear ... BUT ... $$\phi$$ maps from $$M^{(\Delta)}$$ to $$N$$ and we are looking for a mapping $$h$$ that maps from $$M$$ to $$N$$ ...Hmm ... Is $$\phi_\alpha$$ the map we want ... do we need to show $$f \circ \phi_\alpha \ne 0$$ and then take $$\phi_\alpha = h$$ ... ... but then \{ \phi_\alpha \} is not one mapping but a family of mappings ...
Can you help ... ?
Peter
You were almost there: $f \neq 0$, so there is a $y \in N$ with $f(x) \neq 0$.
$\phi$ is an epimorpism, so there is a $y \in \bigoplus_\Delta M_\alpha$, such that $\phi (y) = x$,
it follows that $\phi (f(x)) \neq 0$ and $f \circ \phi \neq 0$.
3) use magical prop.2.1.5 to expand $\phi$ into a sum (see a former thread of you)
4) prove there is an $\alpha \in \Delta$ such that $f \circ \phi_\alpha \neq 0$
5) conclusion
5) conclusion
Thanks steenis ...
Reflecting on your advice now ...
Peter
5) conclusion
Thanks again steenis ...
... But ... just a clarification ... $f \neq 0$, so there is a $y \in N$ with $f(x) \neq 0$. ... ... "Did you mean: " ... ... $f \neq 0$, so there is a $x \in N$ with $f(x) \neq 0$. ... ... "
Peter
You write:
Yes, of course, I am sorry.
and also $f(\phi (y)) \neq 0$, sorry again. I think I was still sleeping ...
Thanks ... OK now ...
Peter
Now consider $$\phi \ : \ M^{(\Delta)} = \bigoplus_\Delta M_\alpha \to N$$Let $$( x_\alpha ) \in \bigoplus_\Delta M_\alpha$$ ...Then by Proposition 2.1.5 we have ...
$$\phi ( ( x_\alpha ) ) = \sum_\Delta \phi_\alpha ( x_\alpha )$$ ... ... where the \phi_\alpha are R-linear maps ... ...Now since $$f \circ \phi \ne 0$$ we have $$f \circ \sum_\Delta \phi_\alpha \ne 0$$ ... ... Now ... $$f \circ \sum_\Delta \phi_\alpha \ne 0$$$$\Longrightarrow$$ for at least one $$\alpha$$ we have $$f \circ \phi_\alpha \ne 0$$ ... ... ... (is this correct?)Now fix/choose one of these $$\alpha$$ so that $$f \circ \phi_\alpha \ne 0$$ ...Then put $$h = \phi_\alpha $$Then $$\exists \ h$$ so that $$f \circ h \ne 0$$ ...Is that correct ...
Peter
All correct, well done.
Peter, there is something wrong with the site of MHB. I will be bach soon
I myself did something wrong.
For the converse you have to construct an R-epimorhism:
$$\phi:M^{(\Delta)} = \bigoplus_\Delta M_\alpha \to N$$
$(M_\alpha = M)$.
This means that you have to find the index-set $\Delta$. I did not find it myself so I will give it away: $\Delta = \text{Hom } (M,N)$. Thus, you use $\text{Hom } (M,N)$ as an index set.
Now use prop.2.1.5 to construct $\phi$, you have done that before. Make diagrams (don’t post them, I trust you can make them).
Last step is to prove that $\phi$ is surjective.
Suppose that $\phi$ is not surjective, what can you tell about $N/\text{im } \phi$ ?
Finally use the hypothesis.
$(M_\alpha = M)$.
Hi steenis ... despite your help (thank you) ... I have not been able to make much progress on the converse ... see below ...
Converse:If for each non-zero R-linear mapping $$f \ : \ N \to N' \ \ \exists$$ an R-linear mapping $$h$$ such that $$f \circ h \ne 0$$ ...
then $$M$$ generates $$N$$ ...
... that is ... $$\exists$$ an epimorphism $$\phi \ : \ M^{ ( \Delta ) } = \bigoplus_\Delta M_\alpha$$ for some set $$\Delta$$ ...Now ... take $$\Delta = \text{ Hom } (M, N)$$ ... ... I am not sure why ... can you elaborate ... ?
So ... let $$i_\alpha \ : \ M_\alpha \to \bigoplus_\Delta M_\alpha$$
and $$\phi_\alpha \ : \ M_\alpha \to N$$ ...
... and then define $$\phi_\alpha = \phi \circ i_\alpha$$ ...Now consider a non-zero R-linear mapping $$f \ : \ N \to N'$$ ...Now we have by our hypothesis that there exists an R-linear mapping $$h \ : \ M \to N$$ such that $$f \circ h \ne 0$$ ... ...... BUT ... where to from here?
Can we take $$h$$ to be equal to $$\phi_\alpha$$ ... hmm ... I don't think we can ...How to proceed? ... can you help further ...Further ... you write: " ... Suppose that $\phi$ is not surjective, what can you tell about $N/\text{im } \phi$ ? ... ... "
Not sure what you can tell about $N/\text{im } \phi$ ... ... can you elaborate ...
Peter
Proc.2.1.5 does this:
Given an index set $\Delta$
Given a family of R-modules $\{M_\alpha | \alpha \in \Delta\}$
Given an R-module $N$
Given a family of R-maps $\{\phi_\alpha : M_\alpha \to N\}$
Then you can construct a unique R-map
$\phi:\bigoplus_\Delta M_\alpha \to N$ satisfying
$\phi \circ i_\alpha = \phi_\alpha$, where
$i_\alpha : M_\alpha \to \bigoplus_\Delta M_\alpha$ are the canonical injections (Make a diagram)
The constructed R-map $\phi$ is defined on $\bigoplus_\Delta M_\alpha$ in this way:
$\phi((x_\alpha)_\Delta) = \Sigma_\Delta \text{ } \phi_\alpha (x_\alpha)$ for $((x_\alpha)_\Delta) \in \bigoplus_\Delta M_\alpha$
Now you repeat this same procedure given the index set $\Delta = \text{Hom }(M, N)$
(We elobarate on $\text{Hom }(M, N)$ later, if necessary)
(we define the $\phi_\alpha$ later)
Thanks for the help, Steenis ...
Certainly over the last few problems, you have helped me to better understand Proposition 2.15 (and hence the nature of the other similar propositions in Section 2.1) ... now I think I have an idea of its nature ...
Just a couple of points ... you write:
" ... ... (We elobarate on $\text{Hom }(M, N)$ later, if necessary) ... ... "It does seem a strange index set to me ... being a set of mappings ... but then I guess as an index set only the correct cardinality matters ...
You also write:
" ... ... (we define the $\phi_\alpha$ later) ... ... " But ... haven't we defined $\phi_\alpha$ when we write: ... ... $\phi \circ i_\alpha = \phi_\alpha$ ...?Thanks again for all your help ...
Peter
steenis said:
In the second procedure: $M_\alpha = M$, of course
Hi Steenis ... Thanks to you clarifying the use of Proposition 2.1.5 I can now see that if we define $$\Delta = \text{ Hom } ( M, N )$$ and then define/assume a family of R-modules $$M_\alpha$$, an R-module $$N$$ and a family of R-linear mappings, $$\phi_\alpha$$ then Proposition 2.1.5 guarantees the existence of a unique R-linear mapping:
$$\phi \ : \ \bigoplus_{ \text{ Hom } ( M, N ) } M_\alpha \to N$$
satisfying:
$$\phi_\alpha = \phi \circ i_\alpha$$ So ... we have a map $$\phi$$ from $$\bigoplus_{ \text{ Hom } ( M, N ) } M_\alpha$$ to $$N$$ (where $$M_\alpha = M$$ for all $$\alpha \in \text{ Hom } ( M, N )$$ ...
Now ... we need to show that the R-linear map $$\phi$$ is surjective ... but how ...
... hmmm ... been thinking of your hint to assume $$\phi$$ not surjective and then consider nature of $$N/ \text{ I am } \phi $$... but can't make any headway about what we know about $$N/ \text{ I am } \phi $$ in the case where $$\phi$$ is not surjective ...Hmmm ... have not yet used the hypothesis regarding $$f$$ and $$h$$ yet ... but ... how do we employ it to show that $$\phi$$ is surjective ... ?
Sorry about lack of real progress ... but can you help further ...
Peter
I am disappointed that you did not answer my question:
"Now you repeat this same procedure given the index set $\Delta = \text{Hom }(M, N)$"
As long as we do not know the wanted R-map $\phi$, we cannot go further. So please construct $\phi$, and while doing that make a suggestion what the $\phi_\alpha$ are. Make a good choice for the index-variable $\alpha$. Of course make diagrams.
But, Hugo, repeating the procedure with $\Delta = \text{Hom }(M, N)$ just gives (as I stated) the mapping
where the copies of M are counted by the number of homomorphisms in \text{Hom }(M, N) ...But then, from your comment I am assuming that I am missing something ...
Peter
Yes, you are missing the construction of $\phi$. Please read my post #14
Decide what the $\phi_\alpha$ are.
hi steenis ...
You write:
" ... ... make a suggestion what the $\phi_\alpha$ are. ... ... "I am thinking that the $\phi_\alpha$ are the h of the hypothesis ... so that $$f \circ h = f \circ \phi_\alpha \ne 0$$ ... and that somehow we use this to show that $$\phi$$ is a surjection ...
Peter
I can see that the map $$\phi \ : \ \bigoplus_{ \text{ Hom } ( M, N ) } M_\alpha \to N$$
is defined by
$\phi((x_\alpha)_{ \text{ Hom } ( M, N ) } ) = \Sigma_{ \text{ Hom } ( M, N ) } \text{ } \phi_\alpha (x_\alpha)$ for $((x_\alpha)_{ \text{ Hom } ( M, N ) }) \in \bigoplus_\Delta M_\alpha$But ... I am thinking of the index set as a counter ... but maybe that is limiting or wrong ... in fact I am puzzled as to how a set of homomorphisms can act as a counter similar to, say, the natural numbers ... can you explain how a set of homomorphisms acts as an index ...Peter
I do not know why you refuse to answer my question, I was trying to make things clear to you. Well I will answer it and do the procedure:Given the index set $\Delta = \text{Hom }(M, N)$
Instead of the index-variable $\alpha \in \Delta$, I will use the index-variable $f \in \text{Hom }(M, N)$
Given a family of R-modules $\{M_f = M | f \in \text{Hom }(M, N)\}$
Given an R-module $N$Given a family of R-maps $\{\phi_f : M_f \to N\}$
NO these $\phi_f$ are not given.
I suggest $\phi_f = f$ for $f \in \text{Hom }(M, N)$.
$\phi:\bigoplus_{\text{Hom }(M, N)} M_f \to N$ satisfying
$\phi \circ i_f = \phi_f = f$, where
$i_f : M_f \to \bigoplus_{\text{Hom }(M, N)} M_f$ are the canonical injections
The constructed R-map $\phi$ is defined on $\bigoplus_{\text{Hom }(M, N)} M_f$ in this way:
$\phi((x_f)_{\text{Hom }(M, N)}) = \Sigma_{\text{Hom }(M, N)} \text{ } f(x_f)$ for $((x_f)_{\text{Hom }(M, N)}) \in \bigoplus_{\text{Hom }(M, N)} M_f$
Now you should have the diagram:
\begin{tikzpicture}[>=stealth]
\node (A) at (1,0) {$M_f = M$};
\node (B) at (1,-6) {$\bigoplus_{Hom (M, N)} M_f$};
\node (C) at (6,-6) {$N$};
\draw[->] (A) -- node
{$i_f$} (B);
{$f$} (C);
\draw[->] (B) -- node [below] {$\phi$} (C);
\end{tikzpicture}​
{$i_f$} (B);
{$f$} (C);
\end{tikzpicture}​
Thanks steenis ...
Have read your post ... but do not follow it yet ...
Will study it now and tomorrow morning ...
Thank you for your patience ...
Peter​
{$i_f$} (B);
{$f$} (C);
\end{tikzpicture}​
Just a thought Hugo ... $$f$$ is the notation for a mapping $$f \ : \ N \to N'$$ in the hypothesis of the converse ...
Won't this cause confusion as we proceed ...
But anyway ... for now focusing on your post and its meaning
Peter​
steenis said:
We will use another notation.
OK Hugo ... thanks ...
I now believe I have understood your post ... at least superficially anyway ...
But ... still cannot see the way forward to prove that $$\phi$$ is surjective ...
I may need some more help ... :( ... apologies ...
Peter
The only thing I want to know if you understand the procedure of the construction of $\phi$. If not, go back to post #14, study the procedure of prop.2.1.5. Then you repeat the procedure for $\Delta = \text{Hom }(M, N)$ without peeking. Choose an appropriate index-variable $\alpha$ and appropriate R-map $\phi_\alpha$. Only if you understand it thoroughly, we wil continue and prove that $\phi$ is surjective.
I believe I understand the procedure ... but I am ging back once again to your post #14 to study it once again ...
Peter
