questtosuccess
- Messages
- 11
- Reaction score
- 0
A block of mass 2.5 kg is placed against a compressed spring (k = 2900 N/m) at the bottom of an inclined plane. When the spring is released the block is projected up the incline and the spring expands by 14 cm to its normal length.
Calculate the maximum distance traveled by the block up the incline.
** the angle of the incline is 28 degrees.
a.without friction.
b. Repeat the calculation with friction, taking µk = 0.22.
E=1/2kx^2
E=1/2mv^2
E=mgy + 1/2kx^2
sin(theta)=opp/hyp
xtotal= x1+x3
for a) I separated the question into 3 situations: the compressed block, the block at normal length, and the block at its highest point
Situation 1: let y=0m here
E1= 1/2kx^2
Situation 2: let x=0m here
E2=1/2mv^2
Situation 3:
E3= mgy + 1/2kx^2
I used Situation 1 and 3...
E1=E3
1/2kx1^2 = mgy3 + 1/2kx3^2
I used trig ratios to find that y3= 0.14sin28
I solved: x1 = 0.0207 , then added it with x3:
xtotal= x1+x3 = 0.14m - 0.0207m
I feel like I'm doing this completely wrong. Can someone explain step-by-step the correct way to solve for this?
b) I know there has to be non-conservative work done, but I have no clue which situation to use... I'm confused, please help !
& THANK YOU
