Block pulled by cord at 15° angle: find speed after 3.9s
  • Thread starter Thread starter BuBbLeS01
    Forces Motion
31 replies · 6K views
BuBbLeS01
A 3.54 kg block located on a horizontal floor is pulled by a cord that exerts a force F = 10.6 N at an angle theta = 15.0° above the horizontal, as shown in the Figure. The coefficient of kinetic friction between the block and the floor is 0.08. What is the speed of the block 3.9 s after it starts moving?
Xcomp= 10.6 cos 15
Ycomp= 10.6 sin 15
I don't know where to go from here :(
How about Newton's second law?
[tex]\sum_{i=1}^n F_i = ma[/tex]
BuBbLeS01 said:
so do I have to find the resultant vector or no?
Did you draw a diagram? Do [tex]\Sigma\vec{F} = ma[/tex] in the vertical and horizontal directions...
Okay so I have come up with the net force for the x and y directions...
Fxnet = Fx + Wx + Nx = Fx + 0 + Nx = max
Fynet = Fy + Wy + Ny = Fy - Wy + 0 = may
BuBbLeS01 said:
Is that set up right?
For the x-direction you wrote:
[tex]F_x + N_x = ma_x[/tex]
What is N_x ? Does the normal force act in the x - direction? what about the frictional force?
For the y-direction you wrote:
[tex]F_y - W_y + 0 = ma_y[/tex]
Hmmm... why didn't you put a normal force here?
Nx doesn't act in the x direction so I put it as 0...
so I have...
Fx/m = ax
For the normal force in the y direction I put 0...
(Fy-Wy)/m = ay
Hmmm... you're missing forces.
List all the forces acting in the x-direction.
List all the forces acting in the y-direction.
Forces in the x-direction:
Tension
Normal
Fricton
Forces in the y-direction:
Weight
Normal
Friction
Tension
There's no normal force in the x - direction. There's no frictional force in the y-direction.
So in the x-direction... you only have the x-component of tension, and the friction... write out the F=ma equation in the x-direction.
In the y-direction... you have the y-component of tension, gravity and the normal force... write out the F=ma equation in the y-direction.
Oh okay...that was a dumb mistake I made...
Fxnet = Tx + Fx = ma
Fynet = Ty - Wy + Ny = ma
Cool.. try to substitute the values of tension, friction, weight etc... into your equations...
I got the friction and weight but I m drawing a blank on how to calculate the tension?
Actually you have the components of tension in your first post. :wink:
okay so the fx = 10.6 cos 15 is actually the tension force not the friction force?
yes, 10.6 is the force the cord exerts... ie tension... so 10.6cos15 is the horizontal component... 10.6sin15 is the vertical component.
then how do I calculate the friction force. I know I have to use the Kinetic friction force of 0.08 but isn't there something else I have to do to it?
Frictional force = normal force * uk
uk is the coefficient of kinetic friction = 0.08
Thats what I thought but isn't the normal force in the y direction 0? So the frictional force would then be 0...that can't be right. I thought the normal force in the y firection was 0 because it lies in the y-axis.
No normal force isn't 0... the net force is 0 in the y-direction (ie ay = 0, may = 0)
so I put...
Fxnet= (Tx + Fx)/m = a
but for normal force is that equal wcos theta?
BuBbLeS01 said:
so I put...
You mean this:
[tex]\Sigma\vec{F_x} = ma_x[/tex]
so substituting into the left hand side
[tex]Tcos(\theta) - friction = ma_x[/tex]
Don't assume that... write the equation for [tex]\Sigma\vec{F_y} = m\vec{a_y}[/tex]
BuBbLeS01 said:
why is it - friction and not +?
Friction acts opposite the direction of motion... ie it tries to stop motion.
Ty - Wy + Ny = may
ok so
[tex]Tsin(\theta) - mg + N = 0[/tex]
So your two equations are:
I also know that friction is uk*N, and I can plug in T and theta so:
[tex]10.6cos(15) - \mu_k*N = ma_x[/tex]
[tex]10.6sin(15) - mg + N = 0[/tex]
The unknowns in this equation are N and ax... you have two equations 2 unknowns... you should be able to solve a...
for finding I have N I have
10.6 sin - 34.73N = -N
can I rewrite that as
10.6 sin + 34.73N = N
so I don't have that -N?
BuBbLeS01 said:
quick question...why is Fynet = 0?
because the block is sliding horizontally... if the tension in the cord is large enough then Fynet won't be zero... but then there won't be a normal force or friction either... the block will lift off the ground... I'll put it this way... the vertical tension in the cord isn't large enough to lift the block... so the block stays on the ground.
As long as the block is on the ground vertical acceleration is 0, hence Fynet = 0.
If you multiply both sides by -1... then you get
-10.6sin(15) + 34.73 = N
