Block sliding Down; find kinetic coefficient
28 replies · 10K views · last reply
cassienoelle
A block is at rest on a plank whose angle can be varied. The angle is gradually increased from 0 deg. At 25.7°, the block starts to slide down the incline, traveling 3.50 m down the incline in 1.50 s. Calculate the coefficient of static friction between the block and the plank.
Motion of a block:
4.81×10-1
(THAT WAS THE FIRST PART OF THE QUESTION WHICH I HAVE ALREADY FOUND.)
Part 2:
Calculate the kinetic coefficient of friction between the block and the plank.
None.
not sure how but i keep getting: .21766
Motion of a block:
4.81×10-1
Part 2:
None.
So, first, you have a FBD correct?
I'll assume that you do.
You should have a weight force going down.
A normal force perpendicular to the plank's surface.
And a friction force going the opposite direction of motion, correct?
Google it real quick and you should get some good notes on it. :smile:
Frozen Beverage Dispenser?!
just kidding. bhaha
Okay a Free Body Diagram. Well mmy professor told me to make one but I don't know how.
But okay, what you said makes sense. A normal force, a weight force and a friction force and then the motion.
Right. Now, when you draw your free body diagram, you'll notice that N is slanted in a particular direction.
You can picture the x-y axis as being slightly rotated, that way the N is now directly on the y-axis, and the f force is now directly on the x-axis.
W is now a hypotenuse going down, with an angle between the W and y-axis of 25.7 degrees.
Before I go on, does the way I (tried) to explain the FBD make sense?
Everything makes sense excpet where the W goes.
Alright, so let me try it a different way.
Consider a normal x-y axis with N going upward directly on the y-axis and the f force going directly on the x-axis.
Now, your W force will be a diagonal line in the 4th quadrant (that is, negative y, positive x).
The angle between W and the y-axis will be 25.7 degrees. Does that make any more sense that way? :smile:
That makes much more sense. :)
You're my new best friend.
Haha. Thanks, just here to try to help.
Now, you need to find the sum of the forces in the x-direction.
Well, let's start by figuring out what N will be.
Since N is pointing straight upwards, and by Newton's 3rd law, N - Wcos(theta) = 0, right?
Now, N = Wcos(theta) -> W = mg, so...
N = mg*cos(theta)
f=[itex]\mu[/itex]N -> [itex]\mu[/itex]mg*cos(theta)...[itex]\Sigma[/itex]F[itex]_{x}[/itex] = mg*sin(theta) - [itex]\mu[/itex]mg*cos(theta) = ma[itex]_{x}[/itex]
Correct?
If you see an error in my reasoning, correct me.
Alright, most of that makes sense. i don't have the acceleration tho to find u?
Alright, well, that's what we need to do next. :smile:
And yes, all three masses cancel out.
Okay. So now we have:
gSin(Theta) - u*g*cos(theta) = a
4.25 - 8.83u = a
Consider that the final velocity will be the Delta x / Delta t.
So, Vf = 3.50 m / 1.50 s
Vf = 2.333 m/s
Now, use your kinematic equation...
V[itex]_{f}[/itex]=V[itex]_{i}[/itex]+a*t
V[itex]_{i}[/itex]=0 m/s
Now, solve for a...
a = [itex]\frac{V_{f}}{t}[/itex]
a = [itex]\frac{2.333}{1.50}[/itex]
a = ?
After that, you can solve for uk.
4.25 - 8.83u = a
That looks to be correct.
it says I'm wrong...
i got a=1.553
so, u should equal .305
...right?
That should be correct. (Unless we did something wrong in the procedure).
we must have done something wrong...cuz it says I'm incorrect.
cassienoelle said:
g is always 9.8 ?
and theta is always 25.7 ?
g is approximately 9.8 m/s^2
Theta will be 25.7 degrees in this problem.
uk may be .322... or .323. I'm not quite sure right now.
Then i have no idea what to do. i relooked my math, and it makes sense to me.
Maybe you could multiply the 1.553 m/s^2 by cos(25.7). Since a would be a vector, and that would, technically, give you ax.
Try that and see if that works for you. I'm honestly confused.
I'm sorry.
I'm honestly stuck on this problem. I think I summed the forces right (since I could solve for us and get the right answer).
But, when it gets to finding the acceleration, I'm confused.
Maybe if I think about it some more...
Don't be sorry. Cuz I'm juust as lost as you are. The problem isn't due till tomorrow at midnight.
No matter how many times I do this problem, I still get .305 as uk...
So, I don't know. Maybe there was a rounding thing that was done somewhere to make it different than .305.
Well thank you.
If anyone else has any help, please, I'd really appreciate it.
