Sampling Time Calculation for Bode Plots: Plant Comparison & ZOH Preceding
The discussion focuses on calculating the sampling time for a discrete-time plant represented in Bode plots. The relationship between sampling frequency and Nyquist frequency is emphasized, with the formula Ts = 1/(2*Nyquist frequency) being central to the calculations. Participants clarify that the highest frequency component should be converted to Hz for accurate sampling rate determination. The final calculation indicates a sampling time of 0.2 seconds based on the given frequency. This highlights the importance of understanding frequency conversions in sampling time calculations.
jami8337
In the figure, the Bode plots of a continuous-time plant (thin line) and of its discrete-time counterpart, representing the discrete-time operation of the plant preceded by a Zero Order Hold (ZOH) (bold line), are displayed. What is the Sampling time used?
I figure it has something to do with f= 1/T, but other than that I am really not sure how to use it with the bode plot, any pointers would be great!
That vertical line tells you something about the highest frequency component you can represent in a discrete-time system, which is very intimately related to the sampling frequency of the system.
Does that help?
Ok, is the highest frequency then represented by fs/2 ?
Yes, the Nyquist frequency of the sampling system.
So if the Nyquist frequency is fs/2 and fs= 1/Ts,
Ts = 1/2*Nyquist frequency ?
Well, to be more precise, Ts = 1/(2*nyquist freq.).
Ah yeah that's what I meant. So the highest frequency here would be about 17 rad/sec? Do i need to convert this into Hz in order to use it in the equation?
Yes. That's because sampling rate is always given in samples/sec. and so the sampling time is 1/sampling rate and fs = 1/2 sampling rate. Avoid rad/sec. in sampling questions, in general.
Ah ok, so (1/2Π)*16rad/sec = 2.55 Hz
Then Ts= 1/(2*fs) = 0.2
Thats great, thanks for all your help!
Right. 0.2s.
