Boiler volume for specific steam turbine?
The discussion centers on determining the necessary boiler volume for a steam turbine operating at superheated steam conditions of 10-12 bars abs and 200-220 degrees Celsius, with a steam consumption rate of 0.04 kg/second. Key insights reveal that the physical size of the boiler is not directly related to its capacity; instead, the surface area for heat exchange is crucial. The user is designing an electric heating system and is considering using Organic Rankine Cycle (ORC) fluids to optimize performance. However, safety concerns regarding the user's understanding of steam systems led to the closure of the thread.
  • Understanding of steam turbine specifications and operation
  • Knowledge of heat exchange principles and boiler design
  • Familiarity with Organic Rankine Cycle (ORC) technology
  • Basic thermodynamics and energy conservation principles
  • Research boiler design focusing on heat exchange surface area
  • Study Organic Rankine Cycle (ORC) fluids and their applications
  • Learn about the thermodynamic properties of steam and ORC fluids
  • Investigate safety protocols for designing steam power systems
Engineers, energy system designers, and students interested in steam turbine technology and boiler design, particularly those exploring innovative heating methods and safety in steam systems.
Golani51
New here, hope someone can help.
I'm experimenting with a heat source for a steam turbine. I have the specs for the turbine and the necessary conditions for operation, but at this point in my design I need to figure out the volume of the actual boiler/reservoir. A direct answer or the right equation would be infinitely helpful. Thanks in advance!
Specs:
Superheated steam 10- 12 bars abs. 200-220 degrees C
Steam consumption: .04kg/second
basic steam rate: 9.8kg/kwh
Other useful I formation: For the 15 kW you will need a steam boiler of minimum 150 kW / 160 kW / 180 kg/h.
Welcome to PF!
Volume isn't really a relevant parameter for a boiler; what matters is surface area of heat exchange. It sounds like you are saying you are designing this boiler from the ground-up and heating using a heat source of your own design. The nature and capacity of your heat source will determine what the boiler should look like.
My heat source can be tailored to the exact temperature needed to run the turbine. What I need in order to design and manufacture it is the size of boiler needed at the optimum temperature etc. I can adjust the heat source to whatever is necessary, but in order to build the boiler I need to know the minimal size needed to run the turbine. (Based on the requirements listed previously.)
That's great: and you gave the steam flow rate and pressure/temperature, so we know the required capacity of the boiler. But again:
...but in order to build the boiler I need to know the minimal size needed to run the turbine. (Based on the requirements listed previously.)
Again, physical size is not directly related to capacity. For example, a gas fired boiler is much, much larger than an electric boiler of the same capacity (example, in the capacity range you need, about the size of a refrigerator: http://www.cleaverbrooks.com/Products-and-Solutions/Boilers/Electric/Model-CR/Index.aspx ). You will need to design the boiler based on how you intend to heat it. So: how exactly do you intend to heat it?
Edit: Also, please note that boilers and steam power systems are very dangerous. Due to the level of knowledge that is implied by your question, we may have to close this thread for safety/liability reasons (right now it is a bit vague to know for sure what you are attempting...). If you really don't know what you are doing and you are attempting to design/build your own steam power plant, I urge you to reconsider. People die this way.
Forgive my wording. I meant volume. I'm not as concerned about the actual physical size. That will end up being a factor of the design itself. Once I know the volume necessary for fluid heated to the proper temperature to run the turbine, I can move forward.
My design is electric in nature. The reason I need to know volume, is so I can determine if the electricity needed to run my heating elements is more or less than what the 15kw generator can produce. My heating elements produce much more wattage of heat than electricity they use. I'm fuzzy on the math, but this has been the focus of a lot of my research.
I'm also curious about using ORC fluids in place of water for the steam. From what I've found, ORC turbines can run on much lower temperatures than steam turbines.
In fact, adding something like acetone to water reduces its boiling temperature significantly. From what I have read it also bonds with the water atoms unlike alcohols and the like. Using such a mixture as a working fluid for the turbine would require less heat, and less wattage, without the difficulties associated with distillation of the mixture.
If I'm totally crawling down the wrong path I'm absolutely open to critiquing from those who know better. That's why I'm here.
That defies the law of conservation of energy.
Perpetual motion machines are science fiction and are a banned topic here at PF.
I forgot to add "under the right circumstances." This is why I was hesitant to explain my heat source. My original question still stands, despite the science fiction.
I know you meant volume - I said volume. You really aren't listening and we are going around in circles. Furthermore:
This is impossible and since you are "fuzzy on the math", probably just an error on your part. This thread is closed for three reasons:
1. It is non-productive because you aren't listening to what you are being told.
2. We don't discuss perpetual motion here.
3. This is dangerous for someone with your level of knowledge to attempt and for liability and safety reasons we can't be a part of it.
16K
  • · Replies 44 ·
