Boiling toluene/water azeotrope mixture?
  • Thread starter Thread starter djh101
    Boiling Mixture
The experiment involving the boiling of a toluene/water azeotrope mixture demonstrated that the boiling point increased from approximately 84°C to a constant temperature around 96°C due to the complete vaporization of toluene, leaving only water. The observed temperature fluctuation was attributed to measuring the temperature of the liquid rather than the vapor, which does not represent the equilibrium state of the azeotropic mixture. In a two-phase system like toluene/water, the boiling point of the azeotrope should remain stable under equilibrium conditions, which was not achieved in this experiment.
  • Azeotropic mixtures and their properties
  • Thermal equilibrium concepts in distillation
  • Temperature measurement techniques in boiling liquids
  • Understanding of two-phase systems in chemistry
  • Research the properties of toluene/water azeotropes and their boiling points
  • Learn about thermal equilibrium in distillation processes
  • Study accurate temperature measurement methods for boiling liquids
  • Explore the behavior of two-phase systems in chemical experiments
Chemistry students, laboratory technicians, and researchers involved in distillation processes or studying azeotropic mixtures will benefit from this discussion.
djh101
Can somebody explain what happened in this experiment? The mixture of toluene/water was heated to its boiling point (without a condenser) of about 84C. Over the course of under a few minutes, the boiling point increased rapidly and then remained constant at about 96C (more or less- it jumped up and down a lot but stayed in the same range).
The constant final temperature is because the toluene was all vaporized and just water remained, correct? But since the mixture was an azeotrope mixture, shouldn't the concentration have remained constant (and the toluene not completely vaporized before the water)? Was this supposed to happen or was it probably due to measurement error when preparing the mixture?
Were you measuring the temperature of the pot or of the vapors?
Temperature was measured of the liquid.
Then that's your problem. Azeotropes are measured under equilibrium conditions, best approximated as the temperature of the condensate in your system. The pot was not in thermal equilibrium with the vapors so your data wanders around a bit. Was the bulb of the thermomer resting on the bottom of the flask... where the temperature is at it's highest?
Well the problem is that it jumped to 96C (near the temperature of water) instead of staying at 85C (the given BP of a toluene-water azeotrope mixture). And yes, the thermometer was near the bottom. It was a microscale lab, though (3mL total solution), and if I had to guess I would think the most likely cause of an abnormally high temperature would be bad measurements (but were it not azeotropic, would the solution still reach a non-azeotropic constant temperature?).
Toluene/water is a two phase system. You were measuring boiling in the water phase.
That makes sense. Thank you.
13K
