Explaining the Science Behind Boiling Water with Ice | Homework Solution
The discussion centers on the phenomenon of boiling water in a stoppered flask using ice, demonstrating principles of Boyle's Law and boiling point elevation. When the flask is inverted, the steam inside cools upon contact with the cooler glass, leading to condensation and a subsequent drop in pressure. This reduced pressure allows the water to boil at a lower temperature than normal, illustrating the relationship between pressure and boiling point. Understanding rapid evaporation is also crucial to grasping this concept fully.
  • Understanding of Boyle’s Law
  • Knowledge of boiling point and vapor pressure
  • Familiarity with the concept of rapid evaporation
  • Basic principles of thermodynamics
  • Research the implications of Boyle’s Law in real-world applications
  • Study the relationship between vapor pressure and boiling point in different liquids
  • Explore the concept of rapid evaporation and its effects on temperature
  • Investigate the principles of thermodynamics related to phase changes
Students studying chemistry, educators explaining thermodynamic principles, and anyone interested in the scientific explanation of boiling and pressure changes.
ahhppull
I need to explain what happened here...
My teacher boiled water in a flask using a bunsen burner. Then he stoppered the flask and turned it upside down and boiled the water using ice.
• Boyle’s Law is the principle that at a constant temperature the volume of a confined ideal gas varies inversely with its pressure.
• Boiling - A liquid boils at a temperature at which its vapor pressure is equal to the pressure of the gas above it. The lower the pressure of a gas above a liquid, the lower the temperature at which the liquid will boil.
So I looked it up, and I don't quite understand it. Heres a website that explained it (http://www.Newton.dep.anl.gov/askasci/chem00/chem00894.htm). What I don't get is why the pressure dropped inside the flask?
My teacher also said we needed to know what rapid evaporation was. I looked it up online, but couldn't find any clear explanations on it, so if any of you guys know, please explain it =D
The pressure dropped in the flask because the steam in the stoppered flask cooled. Turning the flask upside-down brought the steam into contact with the cooler part of the flask. As the steam cooled, water condensed from it leaving the remaining air in the flask at lower pressure. This enables the water to boil at a lower temperature.
That's my explanation...
  • · Replies 0 ·
  • · Replies 26 ·
