- 42,959
- 10,557
The question is about the effect of heating on the voltage/current relationship. If you eliminate the history then there's no heating. You have to assume steady state, that's all.NascentOxygen said:A material where an applied voltage could correspond to either of two currents, depending on its recent electrical history? If there were such a material, that region beyond the current peak would amount to a negative resistance (i.e., a negative incremental resistance).
Complicating this discussion with thermal time constants by introducing the metal into essentially an oven with non-ideal thermal insulation is not appropriate in this thread.
The question does not specify whether the filament is exposed, so radiating, or insulated, so losing heat in a manner proportional to temperature, or something between the two.
The OP is interested in what could happen, and the answer is that with an insulated filament of tungsten at a high temperature the gradient could go negative. The intuitive response we all made that it was impossible turned out to be wrong. Personally, I find this very interesting.
