Bouncy ball bouncing with 9% energy loss per impact
  • Thread starter Thread starter goonking
21 replies · 3K views
goonking
A Bouncy ball is dropped from a window, 28.7 meters above the ground. It bounces inelastically off the ground and bounces up again, but not as high as it stated out. If it looses 9 percent of its kinetic energy every time it hits the ground, how many times can it bounce, and still have a maximum height greater than half the original window height.
1/2 mv^2 = mgh
Since I know it loses 9% of its kinetic energy, the potential will be lowered by 9% each time the ball bounces also.
So I did 28.7 - (0.09 x 28.7) = 26.1
then 26.1 - (0.09 x 2.61) = 23.76
then 23.76 - (0.09 x 23.76) = 21.627
and so on, I keep repeating this until I get an answer below 28.7 / 2 = 14.35 meters.
And after all that, I get the answer to be 7 bounces.Is there a faster way to do this problem?
The question is, how many times can it bounce, and still have a maximum height greater than half the original window height.
The seventh bounce produces less height than half the initial. Count the bounces till the height is still greater than half the initial height, but the next bounce produces less than the half.
What is the relation between the k-th height and the k+1 height? What sequence do the heights make?
Count the bounces till the height is still greater than half the initial height, but the next bounce produce less than the half.
what is k-th and k+1?
k represents the k-th bounce. It is just a positive integer. For example, the height after the third bounce is 0.91 times the height after the second bounce.
ehild said:
k represents the k-th bounce. It is just a positive integer. For example, the height after the third bounce is 0.9 times the height after the second bounce.
the previous bounce is always 1.01 times higher.
28.7/26.11 = 1.01
26.11/23.76= 1.01
23.76/21.62 = 1.01
etc etc
so I can just keep dividing by 1.01 to get a new height.
Why do you divide by 1.01? If the energy loss is 9 percent it means that the energy after the next bounce is 0.91 times the previous one. Dividing by 1.01 produces 0.99 times the previous one, which is 1 percent loss.
The next bounce is 0.91 times the previous one. Considering the heights as a sequence h0, h1, h2... hk what is the relation between one term and the next one? What kind of sequence is it?
oh, I am sorry, I meant 1.1, not 1.01.
Instead of dividing, use multiplication. Loosing 9 % means that 91% remains. Dividing by 1.1 means that 90.90909...% remains.They are not the same.
So how do you get the height after the first bounce from the initial height? How do you get the height after the second bounce?
first height times 0.91 gives new height , then we just keep repeating?
Keeps repeating. How many times is the second height of the initial height? How many times is the third height of the initial height? How many times is the k-th height of the initial height?
ah
the first bounce is 0.91 times the initial height, and the 2nd bounce is 0.82 times the initial , and the 3rd bounce is .73 the initial.
I'm assuming k-th is the height we want it at, which is 14.35 which is .5 times the initial.
goonking said:
ah
How is it symbolically? If the initial height is H the first is
h1= H*0.91,
the second is
h2=H*0.91*0.91=H*0.912,
the third is
h3=H*0.913,
the k-th is
hk=H*0.91k.
So you have the relation
hk ≥ 0.5 .
What is the maximum value of k so as the inequality is valid? How do you express k with logarithm?
ehild said:
logarithm
log(14.35)/log(28.7) = .7935
is that it?
No. Take the logarithm of both sides what do you get?
you mean log h^k ≥ log 0.5
Yes. Do you know how to take the logarithm of something on the k-th power?
Sadly, no. I will just look it up.
ehild said:
Haven't you studied logarithm yet?
yes, but it was a while ago and somethings have been forgotten
log(a b) = log (a) +log(b)
log(a/b) = log (a)-log (b)
log (ak) = k log(a) ... :smile:
what do the eclipses mean?
you mean the dt
you mean the dots? They mean only that there are some more identities.
