How to Find Bound Charges in a Polarized Cylindrical Dielectric Shell?
To find bound charges in a polarized cylindrical dielectric shell, the polarization is given by P=k/s^2, affecting both surface and volume charge densities. The surface charge density can be calculated using the formula sigma=P·n, applying it at the inner radius R1 and outer radius R2. For the volume charge density, the divergence of P leads to ro=-divergence of P, resulting in ro=k/s^2. It is confirmed that using different limits for s at the inner and outer surfaces is appropriate for calculating the respective surface charges. Understanding these calculations is crucial for accurately determining the bound charges in the dielectric shell.
azone
We have a long cylindrical, dielectric shell in the z-axis with inner radius R1 and outer radius R2. The polarization is given by P=k/s^2 (in cylindrical coordinates, it is only in the shat direction, i.e. no zhat or phihat)
Find the bound surface charge density and volume charge density.
I know the general formula for surface charge is sigma=P.normal and for volume charge it is ro=-divergence of P. But I'm wondering if things are slightly altered because it is a shell and not a solid cylinder. Or can I just use the formula and then have a limit for s?
For the volume charge I'm thinking I can just use the formula which will give me ro=k/s^2. But for the surface charge I was thinking of doing two different ones for s=R1 and s=R2 to find inner surface charge and outer surface charge.
Any help would be appreciated.
What do you mean by a limit for s? Since the polarization is given as a function of s, you can find the volume charge density, which would also depend on s, from the divergence.
Yes, that seems correct.
  • · Replies 29 ·
