How Can Green's Function Solve Boundary Conditions for ODEs?
The discussion centers on solving the boundary value problem w'' - w = f(x) with boundary conditions w'(0) = 1 and w'(1) = 0 using Green's functions. The initial attempt involves finding the homogeneous solution and setting up equations for the Green's function, but confusion arises due to the presence of multiple unknowns and boundary conditions. It is clarified that the Green's function must satisfy continuity and a jump condition at the boundary, leading to specific relationships between constants. The general solution of the differential equation is expressed as a combination of a particular solution and the homogeneous solution, reinforcing the standard approach to such problems. Understanding these concepts is crucial for effectively applying Green's functions to solve boundary value problems.
Mr Boom
Given w'' - w = f(x)
w'(0) = 1
w'(1) = 0
Find the Green's Function
The solution to the homogeneous equation is known as:
w(x) = A*exp(-x) + B*exp(x)
For G's function we have:
u(x) = A1*exp(-x) + B*exp(x), u'(0) = 1
v(x) = A2*exp(-x) + B*exp(x), v'(1) = 0
The homogeneous equation is easily solved by plugging in two B.C.s. However, with Green's function we have two equations with two unknowns and one B.C. each. This leaves:
u'(0) = 1 -> B1 = 1 + A1 -> u(x) = A1*exp(-x) + (1+A1)*exp(x)
v'(1) = 0 -> B2 = A2*exp(-2) -> v(x) = A2*exp(-x) + A2*exp(-2)*exp(x)
Since G1 = A(c)*u(x) and G2 = B(c)*v(x), and we have two jump conditions at point c, I don't see how this can be solved. I've done other problems where A(c) and B(c) can be merged with A1 and A2, but the "1+A1" term keeps me from reducing this two two unknowns and two equations. Am I missing something? Is there an implied BC that I'm not seeing?
Thanks
w'(0) = 1
w'(1) = 0
Thanks
The Green's function is the solution of G_a''(x) - G_a(x) = Delta(x-a), where Delta is the Dirac delta fcn. We can regard G_a as G_a(x) = H(x-a), where H''(x) - H(x) = Delta(x). Don't worry about boundary conditions at x = 0 and x = 1 for now. Since Delta(x) = 0 if x < 0 and if x > 0 we have H''-H=0 on x<0 and on x>0. What happens at x = 0? If we integrate the DE from 0 - h to 0 + h, for small h > 0 we get H'(0+h) - H'(0-h) + O(h) = 1. So, we want: (i) H(x) continuous at x = 0; and (ii) H'(0+)-H'(0-) = 1.
We have H = A1*exp(x)+ B1*exp(-x) for x < 0 and H = A2*exp(x)+B2*exp(-x) for x > 0 we need A1+B1 = A2+B2 [continuity] and A2* - B2* - A1 + B1 = 1 [jump condition]. Now, usually we want a Green's fcn on all of the real line, so we usually impose conditions at +-infinity. Let's assume boundedness. Thus, we have B1 = 0 and A2 = 0. Therefore, we now have A1 = B2 and B2-A1=1, so now we can get A1 and B2. The solution of w''-w = f is w(x) = w_0(x) + integral(H(x-t) f(t) dt, t=-infinity..infinity), and where w_0 is any solution of the homogeneous equation. (Here, you could take f(t) = 0 for t < 0 and t > 1, but if your original f(x) is defined for all x, you could use f on the whole line.) We can choose the constants in w_0 to give the desired boundary conditions.
RGV
Ray,
Thank you for the reply. If it's not too much trouble, could you explain where the w(x)=w_0 + int(...) equation comes from?
Mr Boom said:
Ray,
Sure: the general solution of y'' - y = f is any _particular_ solution plus the solution of the homogeneous DE; this is an absolutely standard result that you should have burned into your soul. The integral involving H is just one particular solution.
RGV
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
