Boundary value problem with substitution
10 replies · 3K views · last reply
TheFerruccio
Find the general solution to the boundary value problem.
[tex] (xy')' + \lambda x^{-1}y = 0[/tex]
[tex]y(1) = 0[/tex]
[tex]y(e) = 0[/tex]
use [tex]x = e^t[/tex]
[tex]x = e^t[/tex] so [tex]\frac{dx}{dt} = e^t[/tex]
using chain rule:
[tex]y' = e^{-t}\frac{dy}{dt}[/tex]
Substituting this in:
[tex]\frac{d}{dx}(e^t(e^{-t}\frac{dy}{dt})) + \lambda e^{-t}y = 0[/tex]
[tex]\frac{d}{dx}(\frac{dy}{dt}) = \lambda e^{-t}y = 0[/tex]
[tex]\frac{d}{dx}(y'e^t) + \lambda e^{-t}y = 0[/tex]
From this point, I feel like I am going in circles. I want to get everything in equal powers of [tex]e[/tex], so I can cancel it out, get a general solution in terms of [tex]t[/tex], and plug in the boundary values to find my constants.
Expand out the ODE fully:
[tex] \frac{dy}{dx}+x\frac{d^{2}y}{dx^{2}}+\frac{\lambda}{x}y\Rightarrow x^{2}\frac{d^{2}y}{dx^{2}}+x\frac{dy}{dx}+\lambda y=0[/tex]
This is called the Euler equation, look for solutions of the form x^{n}.
How did you arrive at that?
Here is my attempt at expanding it out fully:
[tex]\frac{d}{dx}(x\frac{dy}{dx}) + \frac{\lambda}{x}y = 0[/tex]
[tex]\frac{dy}{dx} + x\frac{d^2y}{dx^2} + \frac{\lambda}{x}y = 0[/tex]
[tex]x^2y'' + y'x + \lambda y = 0[/tex]
... Ah, I see what you did, ok. Thanks for the tip. Do I even need a substitution with this?
I continued the problem, using the method you suggested, and I ended up with the following differential equation, in terms of t:
[tex]\ddot{y} + \lambda y = 0[/tex]
The general solution to this, in terms of [tex]t[/tex], is:
[tex]y = A\cos{\sqrt{\lambda}t} + B\sin{\sqrt{\lambda}t}[/tex]
Boundary conditions holding true, I get:
[tex]A = 0[/tex]
[tex]B[/tex] is arbitrary
[tex]y(x) = Bsin(n\ln{x})[/tex] where [tex]n = 1, 2, 3, \ldots[/tex]
If you want, I can be more thorough as to how I got this answer, especially if it's wrong!
As I said sibstitute in y=x^{n} to obtain the following:
[tex] \left[ n(n-1)+n+\lambda\right] x^{n}=0[/tex]
We require an equation for n, just like the constant coefficient case, can you say what this equation is?
I think that in general you're over thinking it. You don't need a substitution for this equation.
Using the substitution method, when solving using the second boundary condition, I am ending up with a discrepancy when attempting a solution with both methods, and it's minor.
For the method of substituting like what the problem suggests, I get:
[tex]0 = B\sin{\sqrt{\lambda}}[/tex]
So...
[tex]\lambda = n^2\pi^2[/tex]
Using the euler format, I am getting...
[tex]0 = B\sin{n\sqrt{\lambda}}[/tex]
So...
[tex]\lambda = \frac{m^2pi^2}{n^2}[/tex]
where [tex]m[/tex], in this case, is [tex]n[/tex] in the first method.
I checked my algebra, and I don't see how these can be so different. Is it because [tex]n[/tex] and [tex]m[/tex] are arbitrary, and can combine to equal a single [tex]n[/tex]?
The two solutions are:
[tex] n=\pm\sqrt{\lambda}[/tex]
So the solution becomes:
[tex] y=Ax^{\sqrt{\lambda}}+Bx^{-\sqrt{\lambda}}[/tex]
Then just use the boundary conditions to find A and B.
Really? So, the solution is not periodic at all? That's strange. I kept getting imaginary roots, which, by doing it two different methods, resulted in getting a sine and cosine. I will post my work in a little bit.
I made a mistake in my algebra, my solutions should have been
[tex] n=\pm i\sqrt{\lambda}[/tex]
Then my solution reduces to yours... The solution my method becomes:
[tex] y=\sum_{n=0}^{\infty}A_{n}\left( x^{n\pi i}-x^{-n\pi i}\right)[/tex]
That's actually an interesting notation. It seems to be more properly descriptive of what all the solutions are.
By writing
[tex] x^{k}=e^{k\log x}[/tex]
My solutions become
[tex] y=\sum_{n=0}^{\infty}B_{n}\sin (n\pi\log x)[/tex]
