flyingpig said:
@Ivy
I am not sure if this answers the definition, I've always thought being closed means it contains it's "closes" it's boundary. Infinity can never be closed.
Then I strongly suggest you look up the definition of "closed set" in your textbook or ask your teacher. You cannot do anything with a closed set if you do not kow what the definition is. In mathematics, definitions are "working definitions"- you use the exact words of the definition in proofs. It is not enough to have a vague idea of what something means- you must know the exact words of the definition.
In metric spaces, we have a "distance" or "metric" function d(x,y) and then define the "ball centered at p with radius r" to be the set of all points whose distance from p is strictly less than r". A point, p, in a set A is called an "interior point" of A if and only if there exist a ball centered at p that is completely contained in A. A set is said to be "open" if all of its points are interior points.
One way of defining "closed set" is that a set is closed if and only if its complement is open.
Another way that I like is this: define "interior point" as above. Define a point to be an "exterior point" of set A if and only if it is a interior point of the
complement of A. Define a point to be "boundary point" of set A if and only if it is neither an interior point nor an exterior point of A.
Then we say that a set is "open" if it contains
none of its boundary points and "closed" if it contains
all of its boundary points.
For example, in the real numbers with the "usual topology" (the metric topology where d(x,y)= |x- y|) the boundary points of the intervals (0, 1), (0, 1], [0, 1), and [0, 1] are, for each, 0 and 1. (i am using the standard "interval" notation. Each of these contains all points
between 0 and 1. the "(" or ")" indicates that end point is
not in the set, the "[" or "]" indicates that end point
is in the set.) The first set, (0, 1), does not contain either and so is open. The last set, [0, 1] contains both and so is closed. The other two are neither open nor closed.
But being "closed" has
nothing to do with being "bounded". The sets [0, \infty) and (0, \infty) both contain all positive numbers. The first does not include 0, the second does. (Notice that both have ")" for "\infty. Since \infty is not a real number, it cannot be in any set of real numbers.) Both have the single boundary point, 0. The first set is open because it does not include that boundary point, the secpmd is closed because it does.
One last example- the entire set of all real numbers has NO boundary points. It is
both open and closed because it contains none of its boundary points (it can't- it has none) and it contains all of them (since it has no boundary points, none
is "all".)
Now, all of that is based on one definition of "closed" set. Since you still have not told us what definition you are using, I have no idea if any of this is relevant or not.
