Box dragged along floor at an angle, calculating normal and frictional force
The problem involves a 60 kg box being dragged along a rough, level floor at an angle of 30 degrees with a tension of 150 N in the rope. The box is accelerating at 0.80 m/s², and the main focus is on calculating the frictional force acting on the box.
  • Exploratory, Problem interpretation, Assumption checking
  • Participants discuss the calculation of the normal force using the equation FN = m*g - F*sin(theta) and express uncertainty about the next steps due to the presence of unknowns. Questions arise regarding the horizontal component of the tension force and the net horizontal force required for the box's acceleration.
Participants have explored various components of the forces acting on the box, including the horizontal component of the tension force and the net force required for acceleration. Some guidance has been provided regarding the relationship between these forces, but there is no explicit consensus on the final steps to solve the problem.
Participants note that the coefficient of kinetic friction (μk) is not provided, leading to discussions about whether it is necessary for solving the problem. There is also a focus on the interpretation of net forces and their relation to the box's acceleration.
revere21
A 60 kg box is dragged along a rough but level floor by a rope at a 30o angle to the horizontal. The tension in the rope is 150 N, and the box is speeding up at 0.80 m/s2 (along the floor).
(a) How large is the frictional force of the floor on the box?
Ffrict = uk*FN
I used FN = m*g - F*sin(theta) to calculate the normal force, which is needed because it is a component of the equation to find frictional force. So, FN = (60)(9.8) - (150)sin30 => FN = 588 - 75 = 513
From here, I know that Ffrict = uk*FN, but the only thing I can plug in is 513 for FN, which still leaves me with two unknowns.
Can anyone be so kind as to tell me the next step? Am I missing something? Looking at the problem completely wrong?
What is the horizontal component of the 150 N force?
Then find the net horizontal force. That is equal to ma, which you can get from what you're given.
They don't give you μk, but you don't need it. You don't even need the normal force, although you got that just fine.
The horizontal component would be 129.9 N, I believe. From using cos30 = adjacent/150.
As far as a net horizontal force, where does this come from? Is it just Fhorizontal = 60*0.80 = 48?
Yes, 48 Newtons.
SammyS said:
Yes, 48 Newtons.
So, I take the horizontal component of 129.9 N, and the net horizontal force of 48 N, and plug it into F - f = ma? Is that right? That would give me 129.9 - f = 48, which comes out to f = 81.9 N.
Can you give me one final hint and tell me if that is the right way to finish out this problem?
Yes, that's right.
SammyS said:
Yes, that's right.
Awesome. Thank you, yet again. You, sir, are a freshman-level physics wizard.
  • · Replies 20 ·
  • · Replies 22 ·
