Branches of the complex logarithm
  • Thread starter Thread starter JonathanT
    Complex Logarithm
JonathanT
Find a branch of log(z − 1) that is analytic inside the unit circle. What is the value of this branch at z = 0?
2. The attempt at a solution
Alright so clearly the log(z) function is analytic at all points accept for the negative real axis.
So log(z-1) will be analytic at all points x ≤ 1. My problem is choosing a branch. I'm really bad at doing this. I understand if the function was something like log(z+1) it would already be analytic inside the unit circle using the principle branch. I just don't see how I can choose a branch that is analytic inside the unit circle. I think if I understand this problem I can be prepared for my test tomorrow. Thanks for any help in advance.
As just the real axis is problematic, you can begin in the upper [or lower] part of the plane, choose a branch there, and try to extend this to the interior of the unit circle afterwards.
So if I understand right from what I've got in my notes I can just start my branch at some arbitrary point say something like.
\tau<arg(w)≤\tau+2\pi
Where \tau = \pi/4 maybe?
However, then the function would not be analytic at the angle \tau on the unit circle am I right?
Tell me if this works:
log(z-1) = log(-1) + log(1-z) = Log|-1| + i\cdotarg(-1) + log(1-z)
= 0 + i\cdot\pi + log(1-z)
So I end up with f(z) = log(1-z) + i\cdot\pi
Then I could use the principle argument because now the cut is at real values of x ≥ 1. Which is outside the inside of the unit circle. I have no idea if my logic here is right though.
That should work, right.
Awesome! I think I finally get this. Hope I do well on the test today. Thanks!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
