Branches of the complex logarithm
  • Thread starter Thread starter JonathanT
    Complex Logarithm
The discussion revolves around finding a branch of the complex logarithm function log(z - 1) that is analytic within the unit circle, as well as determining its value at z = 0.
  • Participants explore the nature of the logarithm function and its analyticity, particularly focusing on the implications of branch cuts. There are attempts to define branches and considerations of how to extend these branches within the unit circle.
Some participants have proposed methods for selecting branches and discussed potential issues with analyticity at certain angles. There is a sense of progress as participants share their reasoning, though no consensus has been reached on a definitive approach.
Participants note the challenge of choosing a branch that remains analytic inside the unit circle and the implications of different choices on the function's behavior.
JonathanT
Find a branch of log(z − 1) that is analytic inside the unit circle. What is the value of this branch at z = 0?
2. The attempt at a solution
Alright so clearly the log(z) function is analytic at all points accept for the negative real axis.
So log(z-1) will be analytic at all points x ≤ 1. My problem is choosing a branch. I'm really bad at doing this. I understand if the function was something like log(z+1) it would already be analytic inside the unit circle using the principle branch. I just don't see how I can choose a branch that is analytic inside the unit circle. I think if I understand this problem I can be prepared for my test tomorrow. Thanks for any help in advance.
As just the real axis is problematic, you can begin in the upper [or lower] part of the plane, choose a branch there, and try to extend this to the interior of the unit circle afterwards.
So if I understand right from what I've got in my notes I can just start my branch at some arbitrary point say something like.
\tau<arg(w)≤\tau+2\pi
Where \tau = \pi/4 maybe?
However, then the function would not be analytic at the angle \tau on the unit circle am I right?
Tell me if this works:
log(z-1) = log(-1) + log(1-z) = Log|-1| + i\cdotarg(-1) + log(1-z)
= 0 + i\cdot\pi + log(1-z)
So I end up with f(z) = log(1-z) + i\cdot\pi
Then I could use the principle argument because now the cut is at real values of x ≥ 1. Which is outside the inside of the unit circle. I have no idea if my logic here is right though.
That should work, right.
Awesome! I think I finally get this. Hope I do well on the test today. Thanks!
