Building a pulsejet engine for 110 rupees
  • Thread starter Thread starter ganuganu
3 replies · 2K views
ganuganu
This is the simplest pulsejet you could make and costs only Rs.110 and has got a good throttling range,which you could see in the video..No need to strain much to start this engine it starts in a single attempt..If anyone need to make this design please reply here..Thanks for watching see you all in the next pulsejet video..
This is great! I remember as a kid trying to build a reed pulsejet... Got as far as cutting the reeds by coating spring steel w/ paint and scribing lines / reverse electrolysis machining the metal.
I'd be interested in seeing dimensions / plans - perhaps I can build one for fun one day!
Thanks,
George
Thanks,
George
this is valveless so no problem for us,no need to make valves:cool:..here is the design..All dimensions are in cm..Those are standard pipes so readily available in markets..:smile:
note: place the inlet fuel pipe at a depth of 4.3cm into the intake pipe..The fuel pipe dia is 3mm..
this has really got good thrust,tried to show an cloth near it but i was not able to do it,so much of force from the exhaust pipe..one day i will hook it up to a scale and find out the real thrust..
note: at the end when i tried to show a cardboard the engine got few holes in the welded parts..
