How many steel profiles do I need to support a workshop roof in Santiago, Chile?
  • Thread starter Thread starter Rod_trad
    Building
This discussion focuses on the structural requirements for building a workshop roof in Santiago, Chile, using steel profiles. The user, Rod, seeks to determine the number of beams and joists needed to support a trapezoidal roof structure measuring 38.64 m², while minimizing material use without compromising safety. The proposed materials include rectangular steel profiles (50x20mm, 1.5mm thickness) for beams and square profiles (20x20x1.5mm) for joists. The discussion emphasizes the importance of adhering to local building codes to ensure structural integrity and safety.
  • Understanding of structural engineering principles
  • Familiarity with steel profile specifications and load capacities
  • Knowledge of local building codes and regulations
  • Experience with construction materials, specifically polycarbonate roofing
  • Research local building codes and permit requirements for construction in Santiago, Chile
  • Learn about the load-bearing capacities of different steel profiles
  • Investigate structural design principles for non-load-bearing elements
  • Explore best practices for using polycarbonate sheets in roofing applications
This discussion is beneficial for DIY builders, structural engineers, and anyone involved in residential construction projects, particularly those interested in optimizing material use while ensuring safety and compliance with building regulations.
Rod_trad
TL;DR
Need to know about material strength
Hi, everyone, this is my first time here.
I've been looking for hours and can't find the information/formulas to figure this out, that's why I came.
I'm building a roof for the backyard (workshop) so I can work all year regardless of weather conditions. I know what materials and dimensions I could use to be 100% safe, but I still want to know if I can get away with using less (or different?) material and maybe stretch distances a bit, in short, save some material and some money. So i want to be safe and do things right but not over do it and over spend.
So here's the rundown. I'm going to be as specific as I can.
The space is 38.64 mt2 (416 ft2) in a trapezoid shape with dimensions 8.4x3.3x8.5x4.6 mts (27.5x10.8x27.8x15.1 ft). naturally the floor needs to be clear, so only supported by the sides, no columns.
On the 8.4 mts side it's my house, 4.4 mts (14.4 ft) wide and in the middle, so 2 mts (6.5 ft) clear to either side (the ends will have a column down to the floor (concrete). the height (of the structure) is 3.5 mts (11.5 ft).
On the opposite side is the wall with my neighbor, all 8.5 mts and it's 3 mts (9.8 ft) in height, so rain will run this way. The structure will be sitting on this wall but I'll still run some columns down to the floor, although the weight will be supported at the top. The columns are so I can hang some shelves and cabinets. Can't fasten anything to the wall.
On either side it's clear, so columns will be added where needed.
So I'm going to use steel profiles (rectangular and square) for the structure. I'm using polycarbonate sheets as roofing material (the wavy kind).
To the house (brick, pretty strong) I will be fixing an 8.5mts long profile to support the beams that will run across the space and rest on the neighbor's wall. These beams in turn will support the other 8.5 mts profiles that will run along the space to which the roofing will be fixed. I don't know the terminology but I think the closest to these longitudinal profiles is joist, so that's what I'll call them.
So here's my issue, how many beams will I need to support the joists and how many joists will I need to support the roof, using as little material as I can without compromising safety.
This is the information I haven't been able to find, how much weight can a specific steel profile support, giving the details of said profile. Or, what profile will I need to support the total weight, which is roughly 120kg (264 lb) for the beams, joists and roofing (according to an earlier design I made where all material is accounted for). It's neither too rainy nor too windy where I live (Santiago, Chile).
Profiles dimension are probably different from what you have available.
I'll be using rectangular profiles for the beams, I was thinking that 50x20mm (1.9x0.78 in) should be good, material thickness can be either 1.5mm or 2mm (17 and 15 Ga, if I'm reading the chart correctly). 1.53 and 1.99 kg/mt (1 and 1.34 lb/ft) respectively.
I would like to use 1.5mm if I can, although the price difference is not that much, everything adds up.
For the joists I'll be using square profiles. I thought about using shorter pieces in between the beams but that's going to take forever, so I opted for long joists the entire length, sitting atop the beams (they will be fixed together).
I'd like to get away with using 20x20x1.5mm 0.83 kg/mt (0.78x0.78 in x 17Ga and 0.55 lb/ft) ideally. Other options are:
25x25x1.5 1.06kg/mt (1x1 in x 17Ga 0.7 lb/ft)
30x30x1.5 1.36kg/mt. (1.18x1.18 in x 17Ga in and 0.9 lbs/ft).
I don't think 2mm (15Ga) is necessary for this because it's not really load bearing (that's the beams). It's mainly a place for the polycarbonate to sit on straight and be fastened.
The weight of the Poly is about 41kg (90 lbs).
So with those numbers in mind I was thinking that 8 beams (1 on each end and 6 spaced in between) and 5 joists (1 on each end and 3 spaced in between) should be enough?
Nothing will be hanging from this structure other than some LED light panels, which are very light but I can't find the actual weight. Also it won't be stepped on unless some burglar decides to go roof hopping, which is not really going to happen.
So I think that is it!
Any help would be much appreciated and thank you for reading this far!
Rod.
Rod_trad said:
Summary:: Need to know about material strength
You don't have any building codes for standards to follow in your jurisdiction for sheds, car ports, add-ons, or something as you propose?
Likes berkeman
In most places you need a permit. To get the permit you must submit the plans to the city, and they will judge if it complies with the building codes.
In other words, you have less freedom of design than you think.
Also, because PF is international and because building codes vary by locality, and because structure design and construction is safety related, PF can't offer you specific advice.
Likes jrmichler, russ_watters and berkeman
The above two posts answer your question, so this thread is closed. Also, please keep in mind that building codes are minimum standards that are designed to keep buildings from collapsing or failing under predictable wind, snow, and earthquake loads. It's a very bad idea to make a structure weaker than code minimum.
Likes russ_watters, anorlunda and berkeman
9K
