Building a water heater- using battery and wire
The discussion focuses on designing a water heater using a 6V battery and Nichrome wire to heat 30mL of water from 20°C to 40°C within one minute. The calculations reveal that 2508 joules of heat energy are required, translating to a power output of 41.8W. The necessary resistance for the Nichrome coil is calculated to be approximately 0.8587 ohms, leading to a coil length of 857,142 meters, which is deemed impractical. Participants also highlight potential errors in resistivity values, emphasizing the importance of using correct units for resistivity, which should be ohm-meter.
  • Understanding of thermal energy calculations (mcΔT)
  • Knowledge of electrical power equations (P = V * I)
  • Familiarity with resistivity and resistance concepts
  • Basic principles of electrical circuits and components
  • Research the properties and applications of Nichrome wire in heating elements
  • Learn about the calculation of electrical resistance in different wire configurations
  • Explore the effects of internal resistance in battery-powered circuits
  • Investigate alternative materials for wire heating applications
Students in physics or engineering, hobbyists building DIY heating devices, and anyone interested in electrical heating applications.
zapped
Need to heat 30mL of water from 20C to 40C in 1 min(60s).
Using 6V battery and Nickel Chromium alloy Nichrome wire that has a resistivityabout 10^-6 ohms/meter. So you use the battery and the wire to build a water heater.
Batter has no internal resistance.
1How much heat energy in joules needed?
2How much power do you need to do it in the time indicated?
3What resistance should your nichrome coil have in order to produce this much power in heat?
4Can you create a coil from the wire having these perperties? (length needed)
5If the internal resistance of the battery were1/3 ohms, how would it effect your calculation?
(only explain what you have to do, don't recalculate the size of your coil)
1:mc(delta)=2508J
2:total joules/time(60s) =41.8W
3:R=v/I = 0.8587 ohms
4: R needed divide by the resistance of the wire, so 857142 m
5: I don't get this part but I think that a longer time will be required?
I think the length of the wire I calculated is probably wrong, but I don't know which step I did wrong, so please help, thanks =p
Your calcs look good to me, but this "resistivity about 10^-6 ohms/meter" is unreasonable - better check that number! Looks like gold wire rather than nichrome.
What units have you used in the first step? I got smaller amount of energy needed. And my guess would also be, that the unit of resistivity is wrong. Usually it's ohm*meter, not ohm/meter.
Bulk resistivity is ohm-meter, but for wire of a given CSA you can quote Ohm/meter
Okay. Thanks for correcting.
thanks everyone
I was just unsure about the length of the wire I got
but I get it now =P
  • · Replies 20 ·
16K
