Bullet+block+spring physics homework
The problem involves a bullet colliding with a block of wood attached to a spring, focusing on the conservation of momentum and energy transformations during the inelastic collision. The bullet's mass and speed, along with the spring constant and compression distance, are provided to analyze the system's dynamics.
  • Participants discuss the application of conservation of momentum and energy principles to determine the mass of the block and the fraction of kinetic energy transformed during the collision. There are questions about the correct equations to use and the relationships between the variables involved.
Some participants have offered guidance on using conservation laws to approach the problem, while others are exploring different interpretations of the equations needed. There is an ongoing dialogue about the correct setup for the momentum and energy equations, with no explicit consensus reached yet.
Participants note the challenge of dealing with two unknowns in the equations and the need to clarify the initial conditions of the block before the collision. The discussion reflects the complexity of inelastic collisions and energy conservation in this context.
Jabababa
A 15.0 g bullet with a speed of v = 235 m/s is fired into a block of wood that is initially at
rest on a frictionless surface. The block of wood is attached to a horizontal massless
spring with a spring constant k = 195 N/m that is initially uncompressed. The other end
of the spring is attached to a wall as shown in the figure below. The bullet becomes
imbedded in the block of wood which then compresses the spring a distance of 28.0 cm
before momentarily coming to a stop.
a) Determine the mass of the wooden block.
b) What fraction of the kinetic energy is transformed into other forms of energy
during the inelastic collision of the bullet with the wooden block?
for a) is it like this:
kx = 1/2mv^2
k=195
x = 28cm
m = m of bullet + M of block
v = initial speed
and then solve for M
kx = 1/2(m + M)^2.
And 2nd question i don't know how to start.
Where is the image,Jabababa?
kx = 1/2mv^2
k=195
x = 28cm
v = initial speed
kx = 1/2(m + M)^2.
You are equating kx(force,a vector quantity) with (1\2)mv^2(kinetic energy,a scalar quantity) which is incorrect.
First understand that bullet and block are undergoing inelastic collision.
What happens in an inelastic collision ?
kx = 1/2mv^2
k=195
x = 28cm
v = initial speed
kx = 1/2(m + M)^2.
the equations you wrote isn't correct. Check again.
for 1st question you have to first conserve momentum for bullet-block collision then determine the final velocity of the block+bullet. Now you can apply energy conservation kinetic energy of block+bullet changes to potential energy of spring (1/2 kx^2).
After you solve first question then you would know the kinetic energy after collision, then you can solve for loss of energy by subtracting it from initial energy of bullet. and then calculate the fraction.
Edit: Tanya Sharma got here first, she is also saying the same thing.
oo so i should use this instead:
m(bullet)v + m(Block)v = m(total)v? To find the final velocity? But then on the right hand side i will have 2 unknown variables...
edit: should i be doing this:
1/2mv^2 = 1/2kx^2
then from 1/2mv^2 = 1/2kx^2 i isolate and get m = kx^2/v^2 and sub it into the first momentum equation to find final velocity. Then with final velocity i can find total mass?
1/2mv^2 = 1/2kx^2
There are two masses,bullet and block,so us two different variables,say m for bullet and M for block.Denote velocity of bullet before collision by 'u' and velocity of (bullet+block) after collision by 'v'.
So your conservation of momentum would look like
mu = (M+m)v .
Here M and v are unknown .
Now what happens after collision ? How would you use the distance traveled by (block+bullet) before stopping ?
1/2mv^2 = 1/2kx^2
firstly use different variables as Tanya Sharma already pointed out. You are headed in the right direction. What is the velocity of the block before collision?...its zero
Yes, then do the substitution.
P.S. : Equations
##m_{bullet}.v_{bullet} + m_{block}.v_{block}= m_{total}.v_{combined}##
##m_{total} = m_{bullet} + m_{block}##
##\frac{1}{2}m_{total}.v_{combined}^2 = \frac{1}{2}k.x^2##
  • · Replies 25 ·
